Question about Garden
Assembly need instruction manual for bond lakeland gazebo
Lost assembly instructions for Bond Lakeland gazebo
SOURCE: I need assembly instructions for a wilson and fish...
I didn't have my instructions either, but I finally figured it out. I do the top first. I'm 5'2" and I put it up by myself and this works for me. The leg connections are 6&5 with 6 being on the bottom with little holes near the base stand and 5 being on top. Add the corner connectors and side connectors to tops of 5. Out from the corner connectors add your 7's. Out from the side connectors the 10's for the long side and 8's for the short side. For the top corners add 4 then 3(it is that funky looking rod). In the middle connector add the 11& 12(this will be for the long sides).You will connect corner and sides with 1 (make sure to put the sliding connector on the rod with the Y's at the ends. On the top, top add the last rod. I think you'll be able to figure out how the canopy drapes. I hope I've given the right directions for yours. I put mine up yesterday.
Posted on May 28, 2010
SOURCE: Lost instructions on how to assemble our 10 x 12
Sunjoy Industries i(866)578-6569
Posted on Jun 30, 2010
  • 760 Answers
SOURCE: I purchased an Avid Screen Gazebo several years
Are these the numbers you've tried?
AvidOutdoors.com
P.O. Box 5932
Albany, NY 12205
Phone: 1-518-453-2436
Fax: 1-518-453-0053
E-mail: mail@avidoutdoors.com
Business Hours: 9:00 AM - 5:00 PM Eastern Time M-F
Posted on Jul 26, 2010
SOURCE: I have a Wilson Fisher
There are several gazebo's that you can download instructions at biglots.com: http://www.biglots.com/browseItem/bistro-sets-and-gazebos/2610#
Posted on Feb 10, 2011
  • 794 Answers
SOURCE: LOST INSTRUCTIONS NEED INFORMATION ON
Hi ccostanz3,
Here is the Garden Oasis Customer Service contact number: 1-888-289-8616. Give them a call, with the name of your set and they'll direct you to the correct sub-contractor - who makes your set and can supply you with a manual or answer parts replacement questions.You may also contact Sears, they should have the instruction manual for you. Their # is 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Posted on May 30, 2011
I don't have an idea where to put the bond paper on brother printer. i am confused weather on a tray or at the back of the printer// pls i need help..
normally you put it front. might as well check for any indication like bond paper mark with an arrow telling you how to insert the bond paper.
or
check the manual and look for the instructions on how to insert the bond paper.
Jul 03, 2011 | Computers & Internet
My oven is not getting very hot only warm on both ovens
Both ovens are on separate thermostats. The top oven is not very powerful and takes a long time to warm up. On my oven the top thermostat also under-heats by about 10 degrees. i.e. what ever it says on the dial, take 10 degrees off the actual temperature. I bought an oven thermometer from Lakeland to check what was actually happening and found out about the top oven. In my case the fan oven was spot on with the Lakeland thermometer.
The first thing I would check would be the thermostat sensors for both ovens. The sensor(s) are located at the top right rear of both ovens. The sensors should be bright and shiny. If the are dull and covered in dirt and grease, this may cause the oven thermostat to under-read. Again, go to Lakeland and buy their brush on oven cleaner and follow the instructions. It really works, although you have to keep reapplying if the grease is thick. I use it on all the surfaces in the oven and it comes up a treat! A word of warning. Treat the sensors and the thin wire that comes from each of them with caution as they are delicate. Don't attempt to clean them with a cloth etc, use the brush. (also if you clean the lenses for the oven lamps with the cleaner, you will be able to see what you are doing much easier.
Jan 30, 2011 | Stoves 720EF Electric Double Oven
My fan oven works but doesn't heat up very well - only gets warm even though the indicator is clicking off and saying it's hot - eg 220c
It sounds like the thermostat has gone faulty or lazy. As a check, I suggest you buy the round oven thermomater from Lakeland - I think it is about £5.00 to see what the actual temperature is being achieved. Also check the sensor in the oven. It is the long thin tube located at the top rear right hand side of the oven above the circulating fan cover. The sensor should be clean and bright not covered with grease etc as this may cause incorrect readings. Don't attempt to clean it manually as it is fragile - use a brush on cleaner - again from Lakeland and follow the instructions on the label. If you have to replace the thermostat you will have to take the whole oven out of its kitchen cabinet - the handbook tells you how to do this.
Dec 31, 2010 | Stoves 720EF Electric Double Oven
Oven not heating up properly
Go to Lakeland and buy there oven thermometer - it is about £5. If that confirms the oven is not working as per the readings on the dial, i.e. 160 on the oven control dial is not shown on the thermometer, check the thermostat sensor. It is located at the rear top right hand side of the oven above the heating fan cover. It is about 6 inches long and thin, connected by an even thinner wire. It can be very brittle so treat it with care! It should be bright clean and shiny, if it is greasy and black, that may be your problem. Again from Lakeland buy there brush on oven cleaner and follow the instructions. I use it on all of the oven including the stay clean panels. Brush the liquid on and leave it for as long as necessary. The liquid gradually dissolves all the grease. You can keep reapplying and then when you are satisfied it is clean, wash it off and then dry it with kitchen towel as carefully as possible. try the oven again and see what happens. If you need a new thermostat, try espares and you will have to take the whole oven out of the kitchen carcass and then remove the top and rear panels to do the job.
(The thermostat may just be lazy, so if the Lakeland thermometer shows only 10 degrees out all through the range, I would live with that. Just make adjustements when you use it. My top oven is 15 degrees out).
Dec 17, 2010 | Stoves 720EF Electric Double Oven
Fan oven does not heat up to correct temperature, but the light goes out so it thinks it does. Need new thermostat for the oven but where do I get one from. The oven is a 720EF Heritage
You can try espares. If it is not listed, there is normally a help section where you can send in a request. You will need the model number as well to ensure you obtain the right version. (It could be something like 059040415).
If you want to check what the oven is doing before buying the new parts, Lakeland do a reasonably priced oven thermometer, I think about 4 or 5 pounds to see what temperatures it is reaching. Also check the thermostat sensor. It is the long thin cylinder in the top right hand corner of the oven. It should be clean as a whistle and not covered in grease gunge etc. If it is, this could cause incorrect readings. Don't attempt to clean it manually as it is quite fragile, especially the connecting wire. Leave the sensor in situ and use a paste on oven cleaner which really works ( from Lakeland) and follow the instructions. it should come up bright and shiny. Best of luck.
Dec 10, 2010 | Stoves 720EF Electric Double Oven
I lost the diagram on how to assemble a heavy duty tent gazebo 002. Can you help or tell me where I can find one on line. The company is closed on weekends, I need it today. Thanks
Usually to get the instruction manual for such things i would say you should go to google and search for the manual.
All you have to do is type the gazebo make and model and add instruction manual to it.
Although you might not get the exact model but you are assured to get something quite similar to what you want. I could help you out with the research if you supply me with the make and model.
Hope this solution has been helpful?
Oct 09, 2010 | Sport & Outdoor - Others
I am going abroad tomorrow and want to take my remoska cooker but unfortunately I have lost my instruction and basic recipe manual. Is it possible to download a copy for me to take with me to France...
I checked online and was not able to find a free download for you, however, I did find where you can view various recipes and even buy the cookbook. I also have an automated phone # you can call to order it from them. This is an Australian ph # (02) 99-333-777. The website is: http://www.remoska.com.au/
This website below has the free recipes listed on it. It is in the United Kingdom.
http://www.remoska.co.uk/
This link below is for cooking instructions:
http://www.remoska.co.uk/cooking-instructions-times/
Finally, here is a website where you can buy items and the cookbook for the Remoska.
http://www.lakeland.co.uk/remoska
Have a great trip abroad!
Douglas
Jun 13, 2010 | Ovens
Need assembly instructions for a 10x12 Wilson & Fisher portable gazebo. Lost instructions.
I looked for hours on the internet trying to find this.
Hope this saves you some time. The manual can be downloaded here.
You can show your appreciation by becoming my scribd follower so you can get all my do it yourself posts.
http://www.scribd.com/doc/55393964/Monterey-Gazebo
thanks
Bill Kibbe
Mar 24, 2010 | Wilson A2K 0 1786 H Web 11 1/2"...
Bond Knitting Machine
I have a manual for the sweater machine, maybe I can help e-mail me at agnesnoeth@yahoo.com
Sep 14, 2008 | Bond-America Ultimate Sweater 01008-9
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
