Question about Bionaire Humidifiers
BT200 Manual Where can I find instructions for cleaning this product - ancient, I know. Bionaire BT200 Ultrasonic Humidifier
SOURCE: bionaire BCM630
Remove the water tank from the main unit. Now look down into the unit where the water tank sits. There is a small knob that you need to turn counter clockwise and the lower part of the unit incl the filter will slide out.
Posted on Dec 28, 2007
  • 7 Answers
SOURCE: Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Posted on Feb 12, 2008
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Posted on Jan 23, 2009
SOURCE: Vicks V3100 Humidifier
http://www.kaz.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=285ef863f85db2982e6f095560687917
Posted on Feb 05, 2009
sabharish
  • 297 Answers
SOURCE: HAVE LOST OPERATING INSTRUCTIONS FOR BIONAIRE
Here is the download link for the instruction manual :
http://www.bionaireuk.co.uk/Manuals/MANUALS/BWM5075C-IUK_43_7594830.PDF
It wud be great if you rate this solution!
Thank you!
Posted on Apr 03, 2009
Bionaire BT-200 ultrasonic humidifier have stopped misting, though I can hear a hum as though something is still working. I have two of these in the same state.
I have the same model; it has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up. The scale keeps the disk from vibrating.
Jan 24, 2017 | Bionaire Humidifiers
I need a manual
Try google.
Humidifiers Instruction Manuals at Bionaire.com.
www.bionaire.com/...manuals/humidifiers/humidifiers-manual.html
Browse our Humidifiers Instruction Manuals to find answers to common questions about Bionaire® products. Click here to view on our FAQs now.
[PDF]Crane Owl Cool Mist Humidifier Owners Manual - Sylvane
Dec 18, 2015 | Humidifiers
When I turned on my ultrasonic humidiifier it worked for 10 sec, then I observed the water coming through the bottom. When I removed the tank and the bottom full with water. How can I fix this?
Bionaire BWM401 leaking - YouTube
? 0:39
https://www.youtube.com/watch?v=Gy7VKJJeb3o
Jan 20, 2013 - Uploaded by urhorh
My Bionaire BWM401 leaking through the bottom. ... Review ofBionaire Cool Mist Humidifier BCM7932P-CN from Costco HD - Duration: 1:41.
Nov 28, 2015 | Bionaire Humidifiers
Looking for a manual for BU4000 Ultrasonic Humidifier.
It took much longer than I thought it would but your manual is here:
http://homeappliance.manualsonline.com/manuals/mfg/bionaire/bu4000.html
If it does not come up make sure that you choose the BU4000 only in your search. The BU4000-UC will not bring up the manual.
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Bionaire BU4000-UC Humidifier
I have bionaire cleaning product but no directions on how to use
the cleaning product that you have you need to use once cap full per gallon of water. so if it's 5 gallons you need to use 5 cap fulls. so forth and so forth. that is the easiest way to tell you. and then you let the unit run with the solutions and the water for the hole time until the water runs out. and your unit will be cleaned
Mar 22, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
White dust coming out of humidifier
A concern is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust. The EPA does not issue health warnings about minerals in the air, but does recommend using low-mineral water (such as distilled water) in your humidifier. Many ultrasonic models feature a demineralization cartridge that filters minerals out of the water to prevent the dust.
Good Luck
Apr 05, 2008 | Bionaire BU4000-UC Humidifier
Nov 25, 2007 | Crane Penguin 1 Gallon Humidifier
Humidifiers Logo
191 people viewed this question
Top Bionaire Humidifiers Experts
Vernon Taylor
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
