Can i use a 250v 4a fuse instead of a 125v 4a fuse for my tv emerson 32", will it work
SOURCE: the tv keeps blowing fuses
Hi your problem is that a component(s) inside your TV has probably short circuited to Earth, this then causes a massive current to flow and this blows the fuse. Due to the types of Component failure from this, this TV should go to a reputable repair shop. Get a firm "Quote" and an explanation of what needs to be done.
Posted on Aug 15, 2007
latino
  • 93 Answers
SOURCE: Sanyo tv blows fuse when you turn it on
u have a short in the power supply section
Posted on Oct 24, 2007
  • 1694 Answers
SOURCE: 6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Posted on Dec 08, 2007
SOURCE: 6.3 slow-blow fuse
This worked for me. My set has a little panel around the power cord with a single screw; the real trick is fitting my hand in there to change the fuse. I guess they make the opening for monkeys or small children or something.
Posted on Jan 11, 2008
SOURCE: i can't find a 6.3 125v fuse
If you look on the board that the fuse sits on you will see printed it states 6amp 125 Volt / 3amp 250Volt. This means that you can use either one. I think that is why the fuse states E.6.3 125Volt... I think it means either 6 amp (125 Volt) or 3 amp (250 volt). I noticed on the back of a fuse package that I bought that it stated these were interchangable so I put two and two together.
Posted on May 08, 2009
On my onkyo ht-r592 receiver on the 3 glass tube fuses 1 8A125V, 2 10A125V is it OK to use 250V instead of 125V
NNNNNOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! USE THE EXACT ONE OR BURN UP YOUR TV!!!
May 17, 2015 | Onkyo Audio Players & Recorders
I plugged it into 220V outlet and Brother HL 2140 only accepted 110-120V. Is there a fuse somewhere I can access and replace? THank you.
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
Oct 28, 2010 | Brother HL 2140 Laser Printer
I have a Brother HL2140. It was plugged into a 220v outlet, is there a fuse that can be replaced?
- fuse: 250V 4A
Hope it helps.
Oct 15, 2010 | Office Equipment & Supplies
Can't find 2A 125v fuse replacement for on-off will 250v be OK?
There is no difference between a 125v and 250v fuse. The most important thing is the 2Amp. This fuse is probably the line fuse and could be the only trouble and may have blow with a line surge. Make sure the 2A you use is a Fast Blow Type. If it does blow again you most likely have a internal power supply failure.
Apr 19, 2009 | Sharp Aquos LC-20B2U 20 in. LCD Television
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
The tv keeps blowing fuses
Aug 14, 2007 | Sylvania 6432GG 32" TV
T.v won't turn on at all
The 6.3 Amp 125V fuse always blows on this TV after a while. replace with a 6.3Amp 250V fuse and it should do the trick unless something else is wrong. a 6.3 amp 125V is almost impossible to find so chances are if you find a 6.3 it will work. Tried a 6 Amp 125v at first and it blows after the first time you turn it on and off and then back on again. 250V seems to work well. Hope this works for anyone else with this TV. Beats having to move it to the trash because it is HEAVY.
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
