Question about WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan
It won't turn on
I press the on button and it doesn't turn on
My 3ds xl screen has frozen
Hold down the power button until the screen goes black. Then press the power button to turn it back on. If this doesn't work, you'll have to remove the battery. If it still won't work, send it to Nintendo to fix; your limited warranty should still apply if it's the XL.
Oct 19, 2012 | Nintendo 3DS XL
Tip
I removed the battery and now the car won't start
'I disconnected the car battery/changed the car battery and now my car won't start'
Another common question on Fixya.
You've done nothing wrong. It's simply that the immobiliser doesn't recognise the key.
Put the key into the ignition. Turn the ignition on. Press the LOCK button twice on your remote. Wait 1 minute.
Turn the ignition off and press the UNLOCK button on the remote a couple of times. This will disarm the immobiliser.
The key should be recognised and your vehicle will start.
on Feb 19, 2016 | Cars & Trucks
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 28, 2012 | Dishwashers
The disc draw doesn`t open when i press the open button
standing up or laying down?
when standing they sometimes stick, lay it down and if it still won't open then press down on the casing just above the eject button.
if that doesn't work then the unit will have to be opened, the dvd drive taken apart and completely cleaned.
Nov 15, 2011 | Microsoft Xbox 360 Console
My laptop won't turn on, and the charger doesn't seem to be doing anything. even when plugged in, it won't start. ideas?
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Sep 17, 2011 | Compaq Presario CQ60-220US PC Laptop
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
"ON" button doesn't work; calculator won't
In most cases this cannot be economically repaired... the cost to repair would be more then the calculator is worth...
heatman101
Jun 18, 2011 | HP 48gx Calculator
WeatherWorks CH-1850SFW Riviera Stand (Pedestal) Fan Logo
35 people viewed this question
Top WeatherWorks Dryers Experts
Are you a WeatherWorks Dryer Expert? Answer questions, earn points and help others
