Question about Exercise & Fitness
Total gym 1000 what are the dimensions please. weight/length/width/etc
4 Suggested Answers
vpaaf
  • 115 Answers
SOURCE: I need a excercise chart for an old style weider
No you do not the is a book called the home gym hand book and it will give you all the information on how to use your gym. They also have home gym posters
Posted on Oct 09, 2009
maxtreadmill
  • 832 Answers
SOURCE: instruction for a Carl Lewis multi gym
I suggest that you call the place that you purchased the unit and they should have a manual on PDF or direct you to where get a copy one. Since I am I California I not previ to this line product from our Olympic Champion Go Figure !! I hope you find the manual
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: got cables connected on gym but number one weight
If the top plate is just hovering and you cannot adjust it out. For a while you may have to push the top plate down and engage the selector pin and with use the cable will stretch on its own with usage. Since these are a series of cables it would be difficult to pinpoint which cable is causing this problem. If you want to remedy this call Body Solid and have them send you a new set of cables.
Posted on Jun 11, 2010
I need to know how many gallons of water are in my pool
Formula For Average Gallons In Rectangle, Square Or Freeform Pools:
Length x Width x Average Depth x 7.5 = Total gallons
Formula For Average Gallons In Circular Pools:
Diameter x Diameter x Average Depth x 5.9 = Total gallons
Formula For Average Gallons In Oval Pools:
Length x Width x Average Depth x 5.9 = Total gallons
Formula For Average Depth Of Pools With Slopes:
Shallow End Depth + Deep End Depth Divided by 2 = Average Depth
Jun 18, 2017 | Pool & Spa
How do I work out the storage capacity in liters?
measure the internal dimensions
length X width X height in millimeters if a box or surface are X height if a cylinder
for example( 50 mm X 20mm X 40 mm)divided by 1000 =40 litres
( 1000 cubic mm = 1 litre)
Mar 13, 2015 | Cars & Trucks
What are the dimensions of t his dutch oven?
According to Amazon, the dimensions are as follows: 15 inches in length, by 13 inches in width, by 9 inches in height/depth. It also weights 13.8 pounds.
Feb 16, 2014 | Tramontina Gourmet Dutch Ovens: Enameled...
How do you solve a rectangle is eight inches longer than its width. find the dimensions of the rectangle if the perimeter is 60 cm
The rectangle is 11cm by 19cm.
The perimeter is 60, so the width and length must add to 30. The length is 8 more than the width, or width+width+8=30. Solve that for width, then you can calculate the length based on the width.
If this is homework, be sure to show your work.
Oct 11, 2013 | Lands Phones
Will this amp push 2 2000 watt subs?
hope this helps.
caution
About Power supply wires (MRP-M1000 only)
• 21mm2 is the minimum power and ground cable size
that should be used to connect this amplifier. The
length of these cables should not exceed 1m to assure
safe operation.
• If the length of the power and ground cables exceed
1m, or if you connect more than one amplifier, a distribution
block should be used with 33mm2 or 53mm2
power and ground cables depending on the length
necessary. Ensure that you install a correctly-rated
in-line fuse on the power cable near the battery positive
post.
RMS Continuous Power (at 14.4 V, 20 - 200Hz)
• Per channel into 4 ohms (?1% THD+N)
MRP-M1000 ......................................... 600 W x 1
MRP-M500 ........................................... 300 W x 1
• Per channel into 2 ohms (?1% THD+N)
MRP-M1000 ....................................... 1000 W x 1
MRP-M500 ........................................... 500 W x 1
Total MAX Power
MRP-M1000 ............................................. 1900 W
MRP-M500 ............................................... 1100 W
S/N Ratio
• IHF A Weighted, Reference: rated power into
4 ohms .................................................... 100 dBA
Input Impedance
• RCA IN .................................................. 20k ohms
• SP IN .................................................... 40k ohms
Frequency Response (200Hz/ -3dB) ....... 20 - 200 Hz
Crossover Frequency .......... 50 - 200 Hz (-24dB/oct.)
Input Sensitivity (RCA IN) ............................ 0.2 - 4 V
Dimensions
• Width (Heat Sink/Footprint)
MRP-M1000
......... 320 mm (12 - 19/32")/380 mm (14 - 61/64")
MRP-M500
............... 210 mm (8 - 17/64")/270 mm (10 - 5/8")
• Height ..................................... 60 mm (2 - 23/64")
• Depth .................................... 242 mm (9 - 17/32")
Weight
MRP-M1000 ................................................ 4.2 kg
MRP-M500 .................................................. 2.7 k
Feb 04, 2011 | Alpine MRD-M1000 Car Audio Amplifier
What size battery on 2002 daewoo
Interstate recommends
MTP-86
Mega-Tron Plus - 85 Months - 640 CCA MTP-86(Automotive Truck) Cold Cranking Amps: 640 Voltage: 12 Pro-rata Warranty: 85 Weight: 40 Width: 6.9375 Length: 9.0625 Height: 8Go to any Sears, Firestone, Etc store and get a battery that fits the dimension about.
Feb 10, 2010 | 2002 Daewoo Lanos
R1 dimensions
Length: 81.1 in Width: 28.3 in Height: 43.7 in Seat height: 32.9 in Wheelbase: 55.7 in Rake (Caster Angle): 24.0 degrees Trail: 4.0 in Fuel Capacity: 4.75 gal Dry Weight: 390 lb
Nov 10, 2008 | 2006 Yamaha YZF-R1 SP
Baja dimensions
Length 75 in Width 23 in Height 48 in Seat Height 31.5 in Dry Weight 250 lbs Rated Load Capacity 330 lbs
Nov 10, 2008 | 2007 TN'G Baja 150
I need the following info for my 1999 Audi S3 in relation to the tailgate dimensions: Height.......cm; Length........cm; width.........cm; wight.........kg
Exterior Dimensions
Wheelbase
2519 mm
Front Track
1527 mm
Rear Track
1503 mm
Overall length
4159 mm
Overall Width
1763 mm
Height (unloaded)
1415 mm
Ground clearance
n
Unladen weight in kg / gross weight limit in kg
1375 kg / 1935 kg
Nov 05, 2008 | 2005 Audi A3
Maxtor 5t060h6 hard drive
Hi musician78,
As per your request:
Should the image but not sufficient, pls refer to the linked document.
This document contains the exact physical dimensions as well as all other specifications of a Maxtor 5T060H6 hard drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Maxtor Hard Drive
Exercise & Fitness Logo
26 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
