Question about Exercise & Fitness
Keys fitness milestone 4200
What does SI 2 mean
4200 PRINTER Only wants to print out of tray 1
First you need to verify that tray 2 will print from diagnostics test. Use the arrow keys to scroll down to diagnostics and press arrow key, then use arrows move to paper path test and press arrow again. The default paper path test is tray 2 single copy so just select print paper path test and see what happens. If printer prints from tray 2 then we know tray 2 works and that means you either have a print driver that is forcing printing from tray 1 or your settings on the printer for tray 2 are not correct for what you are printing. Check to make sure the paper size shows correctly and make sure that the switch on the right side of the paper tray towards the back is set for standard and not custom.
Aug 04, 2014 | HP LaserJet 4200 Printer
How to open XT720 FROME korea give to her brother in the philipines
Do you mean you want to open line the Korean network on Motorola Milestone XT720 so that you can use a Philippine network with the phone? You can get the unique unlock(openline) code from Unlock-zone.com and follow their free unlock instructions and remove the network lock very easily.
May 29, 2013 | Motorola Mobility Milestone XT720
What is it when display reading SI 2?
SI 2 - Over voltage protection trip.
Just check if there is any resettable breaker located underneath it. You also may have a cable connection loose.
if it doesn't works for you
You may need to notify Ironman Fitness Customer Service Call Ironman Fitness Customer Service at (800) 750-4766
Mar 14, 2011 | Ironman 220t Programmable Treadmill (225...
I m found LSU error in my Samsung SCX 4200 Printer
the error that you got it shows that tha unit laser is faulty. The only way to remove the problem si to replace the laser unit, if you are not a tech or if you don`t have IT expertesse you must contact a tech.
Dec 04, 2010 | Samsung SCX 4200 All-In-One Laser Printer
Motorola milestone problems.
Trade for another brand. Motorola knows about this problem and many more but will not relase a fix for the united states service providers. You are lucky you can use it as a phone as we purchased 5 within our family and all of them as well and everyone else we know that bought this phone, has the same problems. The reboot is bad enough but the Crystal Talk feature is faulty so other people cant hear you talk, and most times, you cant hear the caller either. Motorola has the gall to release a Milestone 2 without fixing the issues with the Milestone 2.1 verson. Everyone I know who purchased the Milestone will never buy another Motorola again because they dont stand behind their product. No wonder they are in finacial trouble!
Jul 02, 2010 | Motorola Mobility MILESTONE Cell Phone
SI3 error on a very old Keys Milestone 1200. Error is shown immediately after unit is plugged in.
I have the same problem. I just bought the 4200 used. I ran on it in the persons home and it worked fine. I got it home, plugged it in and now it throws up SI3 and SI1 codes and won't run!
Jan 17, 2010 | Keys Fitness Exercise & Fitness
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
