Question about Amcor Heating & Cooling
AF1100E- need connector for exhaust hose for window slide bar
2 Suggested Answers
  • 86 Answers
SOURCE: were can i order parts for this mf8000e
Johnstone Supply
Posted on Apr 19, 2010
How do I change a heater core on a 2008 pontiac torrent
Your best bet would be to take your vehicle to a qualified repair shop ! You'll have to Recover the refrigerant from A/C , drain the coolant .
Remove the evaporator outlet hose and liquid line nut from the thermal expansion valve (TXV).
Remove the evaporator outlet hose from the TXV.
Remove and discard the sealing washer from the evaporator outlet hose. Refer to Sealing Washer Replacement .
Remove the evaporator outlet hose and liquid line from the TXV.
Remove and discard the sealing washer from the liquid line. Refer to Sealing Washer Replacement .
Install a protective caps to the evaporator outlet hose and the liquid line to prevent contamination and desiccant saturation.
Reposition the heater outlet hose clamp at the heater core.
Remove the heater outlet hose from the heater core (1).
Reposition the heater inlet hose clamp at the heater core (2).
Remove the heater inlet hose at the heater core.
Plug the heater core and the evaporator core with clean towels to prevent spillage when the HVAC module is removed.
Remove the HVAC module seal nuts from the front of dash.
Remove the instrument panel (I/P) retainer. Refer to Instrument Panel Retainer Replacement .
Remove the shift control bracket. Refer to Transmission Control Replacement .
Remove the center floor air outlet duct by sliding the duct forward then up at the rear.
Remove the center I/P air outlet duct retainers from the instrument panel tie bar.
Remove the center I/P air outlet duct from the instrument panel tie bar.
Remove the instrument panel tie bar. Refer to Instrument Panel Tie Bar Replacement .
Disconnect the blower motor electrical connector from the I/P wire harness.
Disconnect the blower motor control module electrical connector from the I/P wire harness.
Disconnect the HVAC module electrical connector from the I/P wire harness.
Remove the HVAC module from the vehicle.
If you haven't done this before ,forget it !
Aug 14, 2016 | Pontiac Cars & Trucks
Where can I order replacement parts?
These parts are for what exactly? If it is a car, can you provide the year, make & model?
Oct 17, 2015 | Cars & Trucks
Amcor KF9000E portable air conditioner manual
My amcor kf9000e has stopped blowing cool air. What could be wrong with it?
May 18, 2012 | Amcor AF9000E Portable Air Conditioner
Hello, I need the hose to drain water outside that fits the fridgidair portable air conditioner #FAPO9EP1Z1. Is there another small tube or is there any other hoses or vents that I need? I don't see...
impreston - with out the following parts , you really don't have "just the air conditioner."
1- Flexible Exhaust Hose
2- Hose Adapters
1- Sliding Window Kit
1-Foam Window Seal
1-Remote Control
The drain hose is something you supply. A garden hose, no longer than 5 feet will do if you want it to be a continusos drain, rather than drain into the water collectiong bucket. But, without the first 4 items lister above, you won't be able to operate the unit.
Here is a link that may be of some help to you, since you don't have an Owner's Manual.
http://manuals.frigidaire.com/prodinfo_pdf/Edison/2020252a0373en.pdf
You will beed to contact Frigidaire (1 -800-374-4432 ) for the parts you're missing.
Hope this helped you. Please let me know. Thanks.
Jul 12, 2011 | Frigidaire FAP094P1Z Portable Air...
I got a danby ,and i not no how to use it. there is hole at the back of it, but i do not a hose,what do i do
Unfortunately, the model have has been discontinued. The hole on the back is for an exhaust hole for an exhaust hose that goes out a window. However, there is more to it than just the hose. You need the hose couplings/connectors and the window termination kit. Even though your model has been discontinued, Danby may be able to help you. 800-496-6049
Hope this helps you solve the problem. Please let me know. Thanks.
Jun 08, 2011 | Danby DPAC8099 Air Conditioner
Feul will burp mout of the filler cap no mater how slow I fill the car and the service engine soon light is on, how do I change the feul tank filler vent check valve?
Hi, your EVAP vent valve is likely stuck closed. The valve is under the car near the fuel tank. Remove the valve and check to see if it's stuck. You may be able to restore operation by cleaning the valve with carb cleaner. The valve should be open when no voltage is applied. I have pasted instructions below from autozone.com. Please let me know if you have any questions, and thanks for using FixYa.
jturcotte_1546.gif Vent Solenoid Valve
2.2L & 2.4L Engines
  1. Raise the vehicle
  2. Loosen the EVAP canister vent valve hose clamp and slide the clamp down the hose away from the EVAP vent valve hose connection.
  3. Remove the hose from the EVAP canister vent valve.
  4. Remove the EVAP canister vent valve by placing a pry bar between the valve and mounting surface, and moving the valve forward.
  5. Remove the clip from the EVAP canister vent valve harness connector
  6. Disconnect the EVAP canister vent valve harness connector.
To install:
  1. Connect the EVAP canister vent valve harness connector
  2. Install the clip into the EVAP canister vent valve harness connector.
  3. Install the EVAP canister vent valve by pushing the mounts into the original holes.
  4. Lubricate the hose end with lubricant.
  5. Install the hose to the EVAP canister vent valve.
  6. Slide the EVAP canister vent valve hose clamp down on to the hose connection at the EVAP canister vent valve.
  7. Lower the vehicle.
Apr 18, 2011 | 2004 Chevrolet Cavalier
Cylinderhead torque stc.
Cylinder Head Removal & Installation SOHC To Remove:
  1. Relieve fuel system pressure.
  3. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  4. Loosen lock bolt on tensioner.
  5. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt.
  6. Remove timing belt from camshaft pulley.
  7. Disconnect battery negative cable.
  8. Remove 3 bolts that secure accelerator cable and air intake hose to cylinder head cover.
  9. Detach accelerator cable and place off to side.
  10. Remove the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
    • Vacuum hose from air intake hose
  11. Disconnect mass air flow sensor electrical connector.
  12. Remove air intake hose.
  13. Remove PCV valve from cylinder head cover.
  14. Remove ISC air hose from idle speed actuator.
  15. Remove air hose from behind intake manifold.
  16. Remove 2 screws from high tension wire protectors.
  17. Detach wire loom from holder at rear of cylinder head cover.
  18. Detach vacuum tube at rear of cylinder head cover.
  20. Remove 7 cylinder head cover bolts.
  21. Remove cylinder head cover and gasket.
  22. Disconnect 2 ignition coil electrical connectors.
  23. Disconnect 2 fuel injection electrical connectors at rear of cylinder head.
  24. Disconnect the following electrical connectors;
    • Oxygen sensor
    • Throttle position sensor
    • Idle speed actuator
    • Oil pressure switch
    • EGR vacuum solenoid valve at intake manifold
  25. Disconnect heater hose from elbow.
  26. Disconnect brake booster vacuum hose and cruise control vacuum hose from surge tank.
  27. Detach wire harness from rear of cylinder head.
  28. Disconnect purge control solenoid vacuum hose from intake manifold.
  29. Disconnect fuel hose from fuel connector assembly.
  30. Remove grounding bracket.
  31. Remove 4 bolts and intake manifold bracket.
  32. Remove starter.
  33. Detach water bypass hose from bypass pipe.
  34. Disconnect water hoses from oil cooler.
  35. Disconnect fuel hose from fuel pipe.
  36. Remove exhaust manifold heat shield.
  37. Remove exhaust flange nuts and front exhaust bracket bolt.
  38. Lower exhaust system. Cylinder head bolt loosening sequence kia-03-20-7050.gif
  39. Loosen cylinder head bolts in 3 steps in proper sequence.
  40. Remove cylinder head bolts and washers.
  41. Remove cylinder head, intake manifold and exhaust manifold as an assembly.
To Install:
  1. Install NEW cylinder head gasket.
  2. Install cylinder head, intake manifold and exhaust manifold as an assembly.
  3. Tighten cylinder head bolts in 3 steps in reverse sequence that was used during removal. Tighten bolts to 62 ft lb (84 Nm).
  4. Install front exhaust bracket bolt. Tighten bolt to 20 ft lb (27 Nm).
  5. Install NEW lower exhaust flange gasket and 3 nuts. Tighten nuts to 24 ft lb (31 Nm).
  6. Install exhaust manifold heat shield. Tighten nuts to 35 in lb (4 Nm).
  7. Connect fuel hose to pipe.
  8. Connect 2 hoses to oil cooler.
  9. Attach water bypass hose to bypass pipe.
  10. Install starter and bolts. Tighten bolts to 34 ft lb (46 Nm).
  11. Install intake manifolds bracket and 4 bolts. Tighten bolts to 32 ft lb (45 Nm).
  12. Install grounding bracket.
  13. Connect fuel hose to fuel connector assembly.
  14. Connect the following electrical connectors;
    • Oxygen sensor
  15. Connect purge control solenoid vacuum hose to intake manifold.
  16. Attach wire harness from rear of cylinder head.
  17. Connect brake booster vacuum hose and cruise control vacuum hose to surge tank.
  18. Connect heater hose to elbow.
  19. Connect 2 fuel injection electrical connectors at rear of cylinder head.
  20. Connect 2 ignition coil electrical connectors.
  21. Install cylinder head cover.
  22. Install 7 cylinder head cover bolts. Tighten bolts to 60 in lb (7 Nm).
  23. Install vacuum pipe and 2 bolts at rear of cylinder head cover. Tighten bolts to 60 in lb (7 Nm).
  24. Connect vacuum tube to pipe.
  25. Connect loom holder to rear of cylinder head cover.
  26. Install 2 screws to high tension wire protectors.
  27. Install air hose to behind intake manifold.
  28. Install ISC air hose to idle speed actuator.
  29. Install PCV valve to cylinder head cover.
  30. Install air intake hose.
  31. Connect mass air flow sensor electrical connector.
  32. Install the following;
    • Air hose
    • Air ISC air hose
    • Breather hose
  33. Attach accelerator cable.
  34. Install 3 bolts that secure accelerator cable and air intake hose to cylinder head cover. Timing belt pulley timing marks kia-03-20-7035.gif
    NOTE: Timing belt pulley timing mark and timing mark must be aligned.
    NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  35. Install timing belt.
  36. Install timing belt cover.
  37. Pressurize fuel system.
  38. Start engine and check ignition timing.
Jul 11, 2010 | 1999 Kia Sportage
Need info on swapping an automatic transmission on 2001 S-10 Blazer 4X4
ok.. Start with unhooking the battery, removing both drivelines, exhaust, and crossmember while supporting transmission with a jack. Remove all wiring connectors and hoses from transfer case. Remove starter, and torque converter bolts thru the starter hole..
remove the six transfer case to adapter bolts and slide off the transfer case. Disconnect all electrical connectors, hoses, and unbolt transmission cooler lines. Support the transmission with a jack, and remove all of the bellhousing bolts. You should be able to wiggle the transmission, and get it to back off of the engine and then should be able to lower it. Reverse procedure to install, and make sure the new one has fluid in it before you start it up.
Dec 06, 2009 | 2001 Chevrolet Blazer
Heating & Cooling Logo
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
