Question about Crafts & Hobbies
Mastercraft 11B 435A515
No spark
Looking for proper spark plug for CTC mastercraft snowblower 10-33 model 318 961 515 older model
Pull the Old one out and purchase an E3 Spark Plug. They work great on Smaller engines. There are only a hand full of plugs for small engines...
Nov 07, 2014 | Garden
What spark plug does my lawn mower take 11b-106c401
if its a honda engine then it will probably be either a BPR4ES OR BPR5ES
Jun 05, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What is the proper spark plug for MTD 11B-021C516 lawn mower
Contact MTD if your manual doesn't cover this, or buy a shop manual.
May 23, 2014 | Mtd Garden
Mastercraft tiller manual
Did you really crack the shaft trying to remove the inertia or fly wheel
May 20, 2014 | HP Tools & Hardware - Others
Need to change chain on a Mastercraft MC4000 61DL
I think you could take your chain to a shop that repairs chainsaws and they should be able to get you what you need.
Jun 25, 2013 | Garden
Where can I buy a temperature sensor replacement for an old Mastercraft Extreme 350 MPI Vortec HD engine?
These engines are purchased by Mastercraft complete with all sensors,wiring, computers,ect,ect.. straight from GM and are basicly the same as the automotive version with the exception of some minor issues and tuning. What this means for you is ease of replacement parts!!! It should be a standard Gm temp sensor that looks something like this..
sen-1-083.jpgWhich is readily available at any parts store for roughly 15-25 dollars. You can also take the old one in with you as it has a number on the brass section of the body they can cross reference to get the exact one, but any parts gut worth his wieght in spark plugs, can get you this sensor in a matter of minutes.
Jan 05, 2011 | Boating
Proxim ap 2000 11b/g cardbus driver free?
i dont now how to get my uther computer to use wifi on the proxim orinoco ap-2000 11 b/g hit can u help me
Oct 13, 2010 | Proxim ORiNOCO AP-2000 11b/g Kit 802.11g/b...
I want to download Driver wireless for 802 11b device compatible with vista for Acer Aspire 3050
http://www.fixya.com/support/r4871388-installing_missing_drivers_free_charge
Please rate the review.
May 18, 2010 | Computers & Internet
Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Dec 18, 2008 | Mastercraft Garden
Crafts & Hobbies Logo
102 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
