Question about Microwave Ovens
Dimplex manual 46727
I need to know if a little piece of bronze coloured "paper" should be removed from the inside of the microwave before using it
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Reattaching rubber pieces inside microwave
I might need clarification, but household cement or even caulk should work as long as it's allowed to dry fully.
Posted on Dec 08, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Set up Oster Microwave
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Posted on Jan 18, 2009
EwingElect
  • 276 Answers
SOURCE: What is the cardboard cover inside my microwave for?
It may not be cardboard - it may be a material called mica which is located over where the magnetron is located in the unit. This is a protective cover and if it is what I think it is, do not remove under any circumstances, otherwise you may render the microwave unsafe to use.
Posted on Mar 31, 2009
tav75
  • 50 Answers
SOURCE: how do i take a ge microwave door apart to remove a piece of paper between the two glass panels ?
See if u have any screws on the door(sides , top ,bottom or inside the door) if not with a little screw driver ( -- ) try to open the plastic juction to release it from the metal chasis
Posted on May 04, 2012
There is a piece of cardboard inside covering a metal panel, do I need to remove it?
Interior of microwave ovens are metal, never cardboard. Must be something used for shipping purposes, pitch it.
Jun 17, 2015 | Microwave Ovens
How do i take a ge microwave door apart to remove a piece of paper between the two glass panels ?
May 02, 2012 | GE Microwave Ovens
The "cardboard" type plate over
is a wave cover,can be replace
Jul 03, 2017 | Sharp Microwave Ovens
For the sunbeam microwave sgb8901, do you take off the cover over the oven air vent? It's inside the oven on the right hand side- it looks like a rectanglar silver colored piece of cardboard.
I am also having this same problem i dont know the solution yet, but when you figure it out please let me know, or if i figure out i will repost =]
Aug 30, 2010 | Sunbeam SMW750 Microwave Oven
I have a GE JES1290 series convection microwave. On the inside wall (right side), there is a 2.5" x 5" piece of heavy paper (silver in color) that covers a porthole. During operation, it was this piece of...
That's the waveguide cover whichcovers the opening where the microwaves enter the cooking cavity. What happens is food spatters (especially grease and sugar) on the cover absorb the microwaves and cause the spots to heat, so the cover gets burned. The oven will actually operate without the cover, but it's needed to protect the antenna of the magnetron tube (the microwave source). If food gets back there and burns, it's usually doomsday for the tube and time for a new oven.
The replacement is GE part number WB06X10591. It's available from these folks. I do a lot of business with them, so I can recommend them. Here's another source that has it at a lower price, but I don't know anything about the company. You can also try calling appliance parts places or repair shops and give them the number; they may already have the part in stock.
Mar 09, 2010 | GE JVM1190 Microwave Oven
How do I get our Sharp Carousel R-1611 off the wall. We don't have the manual and the Sharp site doesn't recognize the model.
You need to remove the hood (the grille cover above the microwave door and above the control panel) by lifting up on the bottom of the hood (the plastic should flex pretty easily) and popping it off. On the far left and right you should see two phillips screws, most likely bronze colored. You need to remove them (they are quite long) completely. The microwave will still be sitting on its support arms (which enter the chasis of the microwave from the rear). Once the screws are removed you need to lift the microwave up and pull forward - it should come off of the supports, but you might have to jiggle it a bit.
Don't forget to unplug the microwave and disconnect any ducting before lifting it off of its supports.
Mar 30, 2009 | Sharp R-1610 Microwave Oven
Jan 18, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
HOW DO I ROAST A CHICKEN IN A AC925CHS
Search the internet for “roast chicken recipe for microwave”
Here is one just in case you don’t find one:
Microwave Roast Chicken
3 lbs. chicken
1 tsp. salt
4 tbsp. butter or margarine
1 tsp. paprika
Instructions
Melt butter in a custard cup in microwave. Mix paprika into melted butter. Wash chicken (reserve giblets, these are best cooked conventionally). Sprinkle inside of chicken with salt. Cover ends of legs, tail, and wings with small pieces of saran wrap or wax paper. Place trivet on inverted saucer or small casserole lid in 12 x 7 inch baking dish. Place chicken breast side down on saucers. Brush with butter. Cover with waxed paper. Cook 12 minutes. Remove wax paper or saran warp from legs, tail, and wings. Turn chicken breast side up and brush with butter. Cover with wax paper and cook 12 minutes more or until meat thermometer registers 180 degrees (temperature will increase to 195 degrees during standing).
DO NOT USE MEAT THERMOMETER IN OVEN WHEN COOKING!! Remove chicken from oven; cover with aluminum foil and let stand 15 to 20 minutes before carving. Note: For other weights of chicken, allow 8 minutes cooking time per pound.
Jan 09, 2009 | GE JVM1860 Microwave Oven
Whirlpool microwave does not switch on - no power
A problem with a door switch or door switch mount (like this one) will cause the fuse to blow when the door is opened or closed.
There may be a second fuse inside.
You also need to check the door switches and latches to be sure all the debris is out.
There is often a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 01, 2008 | Microwave Ovens
When we first turn on the microwave there is like a mini-explosion and a fiery spark, but after that the microwave goes through its cycle and cooks the food. But we are afraid to try it again.
pls do not use any aluminum or metal material INSIDE the microwave, this can cause the problem
I assumed, but pls consider the ff info...
Be sure to use nonmetal utensils in the microwave.
For microwave cooking, cut meats and vegetables in uniform sizes to make sure that they cook evenly.
Paper plates, cups, and napkins can be used in the microwave. But don't use foil-lined paper products, paper towels that include nylon or synthetic fibers, or newspaper.
When using plastic roasting or cooking bags in the microwave, discard the wire twist tie and use a plastic fastener or a piece of string instead.
To ensure that food cooks fully and evenly in the microwave oven, stir food and turn dishes periodically while they're cooking.
Jul 25, 2008 | Microwave Ovens
Microwave Ovens Logo
64 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
