Turn off carrier rfl0601el
HELP! I cant turn off my mini split, the remote control is on but apparently it needs to be reprogrammed
  • 147 Answers
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Posted on Sep 30, 2008
  • 3 Answers
SOURCE: Carrier air handler tonnage?
That is a fairly large difference. It is usually ok to have the inside evap. coil and blower up to 1 ton larger than the outside condenser. That will make the unit slightly more efficient as well as less likely to freeze up on low airflow situations. It is not recommended to install a new condenser on an old evap coil. There has been a lot of changes to the design of the coils in the last little while. For example a 10 year old 2 ton coil may only have 3 cubic feet of volume but a new 2 ton coil may have 4 cubit feet of volume.
There are many factors that may have infulenced the decision on what size condenser to install. Many of which can only be done by visiting the home and doing alot of work, checking the duct sizing bioth supply and return, inspecting the insulation and windows of the home etc. etc. Most of the time that never gets done. You can blame the contractor for not doing a complete check, but at the same time you can blame the customer because many contractors that are that good loose the job to a cheaper bid that did not no any of the research. It is a catch 22 for everyone involved.
There is ALOT more to sizing equipment that many people think, sadly that also includes many HVAC contractors. Way too many people use "rule of thumbs" or flat out "guess".
Sorry for the rant but your queston can only be answered by a good well educated HVAC contractor visiting your home. That type of a contractor is getting hard to find these days in such a price competetive world.
Posted on Oct 14, 2008
MNTECH
  • 1543 Answers
SOURCE: Got mini split, lost, remote control, bought
Don't know a code for a universal remote, but you can order a new remote from an appliance parts supplier. If you have the model you posted under, the part number would be WJ26X10152 . (about $25) Make sure you have your exact model number from the model / serial number tag off the product to make sure you get the correct remote.
Posted on Jul 29, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
SOURCE: Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Posted on Jul 06, 2010
I want to know that how mini split system automatic work? there is any thermostate or any other device?
Generally, they are operated by a remote control (similar to a television), although some units do have a wired wall control option as well. The indoor and outdoor unit has sensors that measure temperature (to control the operation of the mini-split) and (once the remote is set) the sensors control the system until it reaches the set point set on the remote.
Jul 25, 2016 | LG LS-K1830CL Cool Mini Split Air...
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
The indoor of carrier split type aircon is having a heating function, if they have , how can I set in the remote control
The Split system control is not working and you need to check thermostat wirings and the control on the splitter
Jan 12, 2015 | Carrier Heating & Cooling
I have two of these units with remote located in one room. All of a sudden, both remotes work the same unit. How can I "reprogram" one of the remotes to control the other unit?
Here is a link to the service manual for your unit. Look for section on programming unit identification for the remote.http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.quietside.com%2Fclassic%2Fdownloads%2FService%2520AQV18_24%2520JAKCV.pdf&ei=uwh1U5PpNM6iqAaHr4DQCA&usg=AFQjCNEAs6FdSrr1lSDgNuNZ_9zvmycdKA&sig2=pILXHK1-yJa9ugqScI1evw&bvm=bv.66699033,d.b2k
May 14, 2014 | Samsung AQV18JA Classic Wall Mounted Mini...
42KEL-024LX
have you tried to call carrier to see if there is a universal remote that may be programed to your mini split system?
Oct 22, 2013 | Carrier High-wall Duct Free Split System...
LOOKING FOR ELECTRICAL DIAGRAM AND OPS MANUAL FOR HAIER HSU-22VCA MINI SPLIT
I cant find the manual but I can help you this the issue you might be having. Let me know. http://www.myminisplit.com
May 14, 2010 | Haier HSU22VCA 22000 BTU Cooling Only Mini...
Cant turn air con of with control
if the remote is lg it haven't code the eye of the plate has burned
Feb 21, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
