Question about Kitchen Ranges
Grundfos cu301 pump not pumping. worked fine. Red light on at bottom of pressure gage and readout.
3 Suggested Answers
SOURCE: Grundfos submersible well pump with Grundfos CU301
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Posted on Sep 30, 2010
SOURCE: Hello, My Grundfos CU301 pump
We had a similar problem, and the CU301 had failed. We just got a new one, so I figured I could take apart the old one without making things worse, and I discovered that the 82 ohm 4 watt power resistor had failed. I don't know if that's the only problem, but that resistor has infinite resistance now. So I ordered a couple of new 5 watt ones from newark.com for 15 - 44 cents (on sale). I'll put one in and let you know if that fixes our old CU301. Nothing else on the board looks blackened or swollen or smells bad.
The new CU301 is only able to communicate with the pump intermittently, so I'm not sure what all is wrong. If I have too much more trouble, I'm going to switch to a Cycle-Stop Valve and get rid of the electronic controllers.
Posted on Jan 02, 2011
No water
Does the motor turn it self off after a couple of minutes of no pumping?= ran out of water. If there is water up to the pump and still no water, check filter/s ( if there is any). Undo V band and check pump internals, impeller may be broken from shaft? When putting back together tap V band with block off wood or back of screw driver evenly as you do up the clamp to stop it distorting
Apr 14, 2014 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Hi guys I have 2 grundfos cri10 vertical pumps (just for water pressure) I changed the expansion vessel which blew and I have primed the vent plug but for some reason every time I power the pump up it goes...
indicates no water supply for the pump
check tap from the tank is turned on
if the vertical ? pump is a submersible (in well type ) check for water in the bore/well
If a jet pump make sure that the whole jet system is primed -not just the pump and again make sure that there is water in the well/bore
Jan 10, 2018 | Grundfos Pumps Grundfos CRI 10 Stack Kit
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Nov 04, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Low pressure from grundfos pump to house
Does your system equipped with pressure tank (pneumatic tank)? If it has, maybe it's already filled with water due to some pinhole leaks. Drain the tank and see what will happen.
Oct 30, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
I have had a Grundfos CME Booster pump installed for some ten months or so. We have a pump room alongside the 150,000 water tank. The inlet is suspended from a float within the water tank, and is about...
Hi Ray, did you ever solve your problem, I have a setup that sounds identical to yours and have the same problem, Grundfos are not been very helpful.
Oct 31, 2011 | Plumbing
I have a grundfos pump for a household water tank. The red failure light keeps coming on. I can start it with a screw driver at the back but, after it pumps to build up the pressure it stops again and the...
It sounds like there is sediment in the pump housing. Take it apart and clean out the area the impeller runs in or failing that change your pump
Mar 13, 2011 | Grundfos Plumbing
Hello, My Grundfos CU301 pump won't start up after we carefully moved it from one wall to another. The power supply is live and indicates power at the terminals in the fixture. No lights come on and I have...
Sep 20, 2010 | Kitchen Ranges
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Kitchen Ranges Logo
105 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
