Question about HP Photosmart 475 InkJet Printer
Hp phtosmart 475 gives 000000009 error
The printer no longer reacts when turning it on - afterwards a symbol most likely representing the turn on button and the number 000000009. Please help
SOURCE: Help!!!
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
Posted on Oct 05, 2008
SOURCE: hp designjet 500ps having problem
system error 81:01
Posted on Jan 07, 2009
  • 97 Answers
SOURCE: HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
Posted on May 20, 2009
komguy
  • 2306 Answers
SOURCE: I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Posted on Jun 22, 2009
Adi_Taticu
  • 71 Answers
SOURCE: i have a printer it is modle is Hp LaserJet
HP 4015 NVRAM & hardrive initialization
Solution
A hard disk initialization will erase and reformat the printer's hard disk. Perform hard disk initialization only if an error code displays on the control panel indicating a disk error. Always try initializing the hard disk before replacing it.
1. Turn the printer on.
2. As the printer performs its power-on sequence, press and hold the Menu button until all three lights on the control panel are lit.
3. Press the back arrow . The message INITIALIZE DISK displays on the control panel.
4. Press OK. The printer initializes the hard disk and continues the power-on sequence.
CAUTION: Initializing NVRAM resets the serial number, the model number, the event log, the page counts, and the EIO card. Use the SERVICE menu to restore the serial number and page counts. You also need to reconfigure any computers that print to this printer to recognize the printer. Initialize NVRAM only when absolutely necessary. In most situations, use a cold reset to return printer to factory defaults but still retain the needed values in the SERVICE menu.
 NVRAM initialization
Before initializing NVRAM, print a configuration page and a supplies status page to gather the service menu values
1. Turn the printer on and watch the control panel display.
2. When the display shows the memory count, press and hold the down arrow until all three lights on the control panel are lit
3. Press the up arrow .
4. Press Menu . The message SKIP DISK LOAD displays on the control panel.
5. Press the up arrow until NVRAM INIT is highlighted, and then press OK. The printer initializes NVRAM and then continues its power-on sequence.
daca aceasta procedura nu reuseste, atunci va trebui sa inlocuiesti formatter-ul. daca nu exista hard disk
Good luck
Posted on Dec 13, 2009
Testimonial: "Thanks once agane from whom to send me this link. this solution was so helpful for me,if you are don't send me this solution we were jam.thanks fixya"
I have an HP 5500 59.3K Printer Error
Unplug the printer from the power wait about 10 seconds and plug it back in. Turn the printer on and see if the error comes back. If so, contact an HP representative.
Jan 16, 2017 | HP Color LaserJet 5500 Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Jul 29, 2011 | Canon LASER SHOT LBP-2900 Printer
Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service...
Error in pressure release mechanism
Although passing 2.5 sec from the start of HP control, HP (pressure condition) cannot be controlled.
For more help visit cbrtechsolutions
May 13, 2011 | Kitchen Ranges
I replaced my magnetta printer cartridge, which I bought from target last night. The printer is keep telling me the catride is empty. I put another new one and I am getting the same message. It won't let...
I think that printer has the number keypad, right?
Try this:
  1. To reset this printer, make sure the printer is on. Unplug the printer without turning the printer off.
  2. Wait 60 seconds.
  3. Hold down the # and 6 button while plugging the printer back in. Keep holding the # and 6 down while the printer turns on. After a bit, on mine there was a picture of the power symbol that appeared on the printer display.
  4. When the power symbol appears on the printer display, take your fingers off the # and 6 button.
  5. Push the power button to turn the printer off. Push the power button again to turn the printer back on. The printer will take some time to go through some preparation. When the preparation is complete, the printer will recognize that the cartridges are full.
I am an HP employee. I do not represent HP on this site.
Nov 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
I just installed two ink cartridges in my HP Photosmart 7250 and every time I try to print it says the yellow cartridge is empty and it will only print in black, not color, but when I select black only it...
I just had the same problem on my printer and found that resetting the printer solved the problem.
  2. Wait 60 seconds.
Oct 25, 2010 | HP Photosmart C7250 All-In-One Thermal...
What E means for hp deskjet 2200 problems?
Well 'E' means 'Error', it represent error like - E:461, what is the error in your printer screen? Post further information for detailed solution.......
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | HP Business Inkjet 2200 Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
Need a user manual for HP photosmart 475
hello, yes you can dowload it from the hp website in PDF format.
HERE
Feb 23, 2009 | HP Photosmart 475 GoGo InkJet Printer
HP Photosmart 475 InkJet Printer Logo
64 people viewed this question
Seeker5211
Seeker5211
