Question about Scotsman Kitchen Appliances - Others
Machine won't turn on
Recently moved our ice machine. it's been unplugged for a few weeks. when I plug it back in the lights or nothing happens??
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Check and make sure you have power at plug. if so then make sure you turn machine on. if it is a small under counter unit then the switch is behind the cover down at floor. if not then pull front cover on the ice head and push the freeze tab.
Posted on Jul 07, 2014
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
Posted on Apr 04, 2013
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
The unit worked fine when i last used it in the fall. I plugged it back in today and all the buttons lit up for about 1.5 seconds and then all the buttons went dark again. So I pushed the "on"...
I have had a problem like this in the past you can try taking the electric access panel usually on the side of the equipment. then look inside you will see a wiring harness inside and it literally takes nothing to bump it loose. This happens when people move these units they are pretty fragile and can be tempermental. Make sure the unit is unplugged while you adjust the wiring harness. If that deosnt work your display board is probably bad. Hope that helps
May 10, 2011 | Haier ESA3125 Wall/Window Air Conditioner
NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Kitchen Appliances - Others Logo
41 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
