Disassemble a dcp540cn brother printer - Office Equipment & Supplies
FAN Failure
You need to disassemble case to access the cooling fan inside.
Get a replacement fan from Brother.
If desperate.,peel off the fan label and oil (using sewing machine oil) the fan spindle bush or bearings.
Reassemble.
Jul 24, 2014 | Brother HL-2270DW Wireless Mono Laser...
Troubleshooting and rutein maintenance
Sir/Madam
I Suggest You Follow all Instruction Written On Brother Printer Official Website http://solutions.brother.com/Library/ug/dcp540cn/east-en/html-uk/ug/appendix12.html
I Hope You Fix Your Printer Issue
Or
In Case You Having Still Printer problem Then Follow Us For On:
Brother Printer Support
Jan 21, 2014 | Brother MFC-7340 All-In-One Laser Printer
Disassemble Brother MFC 240C
I know this issue may have been resolved by you already, since I am now looking at this issue for you, however I am setting up the answer to help others that may have a similar problem in the future. You will need to reference a Brother servicing manual as it will show you how to remove the printer assembly and includes part numbers that you may need to replace. Hope this is helpful! You can find the manual at: ftp://ftp.brother.co.il/fax/MFC845.pdf
Dec 27, 2013 | Brother MFC 240C All-In-One InkJet Printer
I have a continuous rear paper jam in brother mfc 8950dw. It looks to be at the fuser in the back but I can't find out how to remove or replace the fuser.
Hello, If you are not a service tech you sould take your mfc to a service, it is not that easy to disassemble this machine.
Nov 03, 2013 | Brother MFC 8950DW Laser Multifunction...
My print View comes blank page?
Try with another toner cartridge, if no result you have to disassemble laser module and clean it with cloth and alcohol.
Feb 08, 2011 | Brother HL-2040 Laser Printer
Paper jam - paper has ripped leaving a piece inside
you can disassemble your printer down to the shell almost. Take off the back and the front to get to the jam easier. Try compressed air if needed.
Sep 28, 2010 | Brother HL-2040 Laser Printer
How to clean printer drum
Follow the steps
1. Remove the drum
2. Disassemble the drum
To disassemble the drum you'll need to remove the E-clips from the bar holding the photosensitive drum in. Do this with a smll precision screwdriver. Insert it in the space between the e-clip and the bar and twist it to push it off of the bar. Be careful not to lose these. With these removed, gently pry off the pieces underneath. The bar should slide out now. With…
3. Clean the parts with a brush
4. Reassemble the drum
5. Test for a print
Kindly rate my help+ Thank you.
May 10, 2010 | Brother HL-2040 Laser Printer
Brother mfc-420cn printer envelope jam
If you did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If you don't find anything you may need to disassemble the printer to find it
May 14, 2009 | Brother MFC 420CN All-In-One InkJet...
Disassemble
Hi , If you like i have suggestion , do you have vacuum cleaner having small extension can reach to the nest of ants .
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
15 people viewed this question
jasbo
jasbo
