Question about Neptune EL70T Elysee Whirlpool 69-1/2" x 39
Elysee bodyman digital 10 - Neptune EL70T Elysee Whirlpool 69-1/2" x 39
Lost manual for elysee electra bodytoner
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
You might also want to post this question in a category other than "Phones."
Thank you for using FixYa.
Dec 24, 2011 | Lands Phones
Tip
Automobile headlight and lens cleaner
# 1 Old automobile bodymans trick: sand lens with # 1200 sand paper,
use any automobile body rubbing compound and then clean off with
a soft cotton rag or towel. good luck!
#2 squeeky fan belt, mix some cheap dish soap in a spray bottle
and spray on fan belt or belts if belt stops making noise, just
replace fan belt. good luck!
on Jun 25, 2011 | Chevrolet C3500 Cars & Trucks
2004 Sable hood release is not working (cable broke) I bought used how can I access the engine compartment externally. Need to replace battery. My garage isn't open today.
a coat hanger or solid peice of steel rod will be needed to use to grab onto the hood latch
it is not an easy thing to do for you need to fish the wire to the hood latch and snag onto the area were the hood cable attaches to
with the end of the wire bent into a J hook you can pull on the cable which will in tun open the hood.
This is maining performed by bodymen when disassembling wrecked vehicles to open the hood
If you know a good bodyman he can help you too if need be
Feb 12, 2011 | Mercury Sable Cars & Trucks
The hood release handle on my 1978 Corvette broke. Is there an emergency hood release cable on the car? And if so, where is it?
I don't think there is an emergency hood release cable, However, a body shop may know a trick to getting it open for you without damaging anything.
Jul 05, 2010 | 1972 Chevrolet Corvette
How can you open the hood of a 98 chevy 1500 P/U with hood latch cable missing?
You will need a long pick to access the latch to open as a bodyman would
Jun 24, 2010 | Chevrolet 1500 Cars & Trucks
Iam needing to purchase another on!
Thanks for using Fixya.
You can buy Emjoi Petite Facial Two-in-one Facial Care Tool AP-91 Hair from this link.
Good luck.Rating the solution is highly appreciated.
Mar 13, 2010 | Emjoi Petite Facial Two-in-one Facial Care...
Dent in tank. bodyman need's colour code to match paint.suzuki ls 650 silver he can save decal's [$160.00 for 2} if he can match the paint
Its called Variable Silver the code is YV2 and if he is using ColorRite the top is 4297
Hope that helps
Found at colorrite.com
Jan 15, 2010 | 2004 Suzuki LS 650 Savage
New map downloads to tomtomxl1
Out of range should not occur. I am in australia and I have French maps and I can request Chans Elysee" and as soon as i get satellite I get a mileage and a drive carefully. I can flick it all the way to the beach and see the ocean i would cross to get there. A long trip and a wet one in a car! It might depend on the version of the map and the coverage ( usually 98%) Perhaps contact ToTom and pose the question of reliability. I would think the maps would work fine despite the message.
Aug 12, 2009 | Tomtom One XL GPS Receiver
Latch problem
My wife did the same thing to my truck. I am a bodyman so I know your problem. The Latch mech that is held by the 3 screws you mentioned needs to be replaced. The release leaver that engages your door strycker is not returning to the correct position when you press the door button. the inside door leaver activates the mech from a different position and has more throw so it often releases. Unfortunately the latch is very expensive at least I think so!
it is a bit complicated to exchange so get someone who has done it a few times... not much room in there to connect the leavers. Phil
Jun 11, 2009 | 1998 Jeep Grand Cherokee
Sliding door won't close/latch
First you need to determine if the issue is a door sliding issue or a door latching issue. These are 2 separate problems.
If the car/van was in an accident-take it to the bodyman.
If the railing is dirty or has a nail, penny, etc in the way this would also cause problems.
If the latch is already closed on the door lick it can't engage since it is already 'latched'.
Isolate the problem - try again! TJ
May 29, 2009 | 1994 Dodge Caravan
Neptune EL70T Elysee Whirlpool 69-1/2" x 39 Logo
Top Neptune Home Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
JonSnell Electronic
JonSnell Electronic
Are you a Neptune Home Expert? Answer questions, earn points and help others
