Powersat ps5 all channels say no signal
I can't get my PS5-22V to send out any signal. I don't know what the problem might be. In the "Link Setup" section I choose Access Point. In the "Network" section I have tried...
this is an infrastructure scheme because it involves not just radios associating with each other but
also a bridge to an external service the 'backbone' network.Your link appears to have a low signal
level for such a short path. I would have expected 5 to 10dB higher. You don't mention your rf setting; I'll assume 23dB.These radios do have a narrow 6deg beam,so that could be an issue. You don't mention your ACK settings, so I can't guess at that.You don't mention your bandwidth settings or the QOS reported by the radios.Two questions perhaps obvious Have you upgraded to the latest firmware? Have you made a speed test at the 'backbone' if so, does it show 10Mbps?
A couple of quick notes First, you're running very old firmware two full levels below current. Update.
Your SNR is low--especially for a short link. It appears you have interference also indicated by a low CCQ number.Do a site survey (from each end) and try to find a channel with less activity.Your rf level is at maximum; radios don't work at their best like that. I would try at least 3dB lower.Of course this will lower your received signal, which is already low. Something is sour in your path; try moving the radios a foot or three in any direction.
Nov 02, 2011 | Ps tation 5, PS5-22V 802.11a Access Point...
Vorrei scaricare i driver per la mia scheda madre modello asustek ps5 mx se
http://support.asus.com/download/download.aspx?SLanguage=en-us nessuna lingua per la lingua italiana del Regno Unito di uso State cercando una scheda madre P5P800 per cercare
Jan 06, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Canon iRC 3380i error code E00025-002...help please?
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Jun 15, 2010 | Canon C3380i Color Copier
Wire broken on PS-PS5 AC ADAPTOR
Your problem is not one that can be fixed over the Internet.
Instead, take your adapter either to a local computer-store, or to a local audio/video/TV repair-shop, and see if they can fix it.
Apr 08, 2010 | Tascam PS-PS5 Power Supply Power Supply
How do I tune a Panasonic TV - TX28 PS5 model from the UK to Singapore channels
if you can go to panasonic website and enter your model number and see if there is anything in there that would help. or use menu and look in there to see if you can spot the uk and then change.
Mar 10, 2010 | Televison & Video
"No Signal" on channel 9
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly.
Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good.
You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
Mar 22, 2017 | Vizio VW32L 32 in. LCD HDTV
Tascam 424 portastudio mkII
Okay I have found two solutions here. They may both be the same but the information here is kind of vague so I will post them both. I have found a PS-PS5 power supply as the title suggests. It can be found here: http://www.supermediastore.com/tascam-ps-ps5-power-supply-for-trainer-series.html I have also found a power supply for the Tascam 424 mkii which can be found here: http://cgi.ebay.com/Tascam-PSP424-Replacement-Power-Supply_W0QQitemZ7405614833QQcmdZViewItem Hope this helps!
Jun 10, 2007 | Tascam PS-PS5 Power Supply Power Supply
Computers & Internet Logo
David Payne
David Payne
