In the interest of saving electricity, is there any way to turn off all those annoying power indicator lights, charging lights, LEDs, etc? Like on the stove, microwave and nearly every other piece of electronic machinery ever made.I guess I want to know how much electricity are these things sucking over time? When I get up to use the bathroom at night it's a virtual light show!
Not much power is generated by those lights, I can assure you! Most LED bulbs are so small they only generate a fraction of money that a standard light bulb uses up. Especially if its just on household appliances. If you just switch them off at the mains and only use them when you need them as you would any other appliance youd be saving yourself some money in the long run.
replaced the bearings both 240vac motors and have reassembled the lot but have misplaced my wiring...
(More)
replaced the bearings both 240vac motors and have reassembled the lot but have misplaced my wiring sketch i drew to rewire the unit it includes a 24v relay with 8 screw terminals on the mounting block the relay unplugs from the block
The Dyson motor turns on, but the brush is not turning. What do I do? If it is a belt, we need to...
(More)
The Dyson motor turns on, but the brush is not turning. What do I do? If it is a belt, we need to know where it is located and how to get into it.
I have the dustbuster in 4 pieces: 1) the plastic cover 2) the motor/handle 3) the plastic cup with...
(More)
I have the dustbuster in 4 pieces: 1) the plastic cover 2) the motor/handle 3) the plastic cup with the 3 tabs that holds the filter 4) the filter. I just need to look at an illustration of how to re-assemble the dustbuster. Can you provide an online illustration of the order? Thanks
I leave my dust buster plugged it it lays on the floor and since I've had it it doesn't stay...
(More)
I leave my dust buster plugged it it lays on the floor and since I've had it it doesn't stay charged. It actually runs for like 1-2 minutes and dies out. It's been like this since I had it but never had the time to check into it.
