Question about Pool & Spa
Zodiac cybernaut Nt
My robot keeps cleaning the same part of the pool
mjhedger
  • 25 Answers
SOURCE: Zodiac G4 will not move
Verify nothing is stuck inside the vacuum. Try adjusting your intake valves to reduce flow from your skimmer(s) and increase flow from the vacuum. Also, how old is the diaphragm inside the vacuum? Inspect it for rips and tears. Also, check the flex hose for rips and tears as well.
Posted on Aug 25, 2009
  • 10 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner hose tear
I haven't seen any bulletins on the Zippy hoses. You might adjust the flow to the cleaner. You can find the Manual for the zippy cleaner on this page beneith the diagram. It shows how the star control works. You can also contact the Mfg Technical Support at Phone: 800-822-7933 They might be able to warranty a hose or two for you.
Posted on Nov 05, 2009
  • 366 Answers
SOURCE: the zodiac works for seveal minutes, then the pool
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Posted on Nov 22, 2009
  • 990 Answers
SOURCE: Zodiac Baracuda Zippy Pool Cleaner only clean one
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Posted on Jul 05, 2010
jharwell668
  • 640 Answers
SOURCE: zodiac pool cleaning head not working
If you are referring to the head floats on these pool cleaners, you probably mean that you have water in your head float. If this is the case, you just need to buy a new head float and replace it. They are inexpensive and easy to find from Polaris or a pool supplies dealer.
Posted on Oct 11, 2010
My aquabot keeps trying to come out of the pool
Aquabots are interesting little robots! They're made to clean the entire surface of the bottom of the pool, and in regards to cleaning the sides, they are programed to climb walls, but once they reach the surface the programming recognizes the specific angle of the top and sends it back down the wall. Normally an Aquabot should never leave the pool. It should reach the surface and go back down the wall to continue cleaning. Good luck!
Pool Remodeling in Clearwater FL
Jul 17, 2014 | Aquabot In - Ground Robotic Pool Cleaner
Cybernaut nt pool cleaner
take to your pool people and let them do it .. you may void the warranty..
Nov 05, 2013 | Pool & Spa
I can't get my pool to backwash
vacuum bottom algae to waste look for it on multiport
Nov 24, 2017 | Hayward SAND FILTER, PRO SERIES
Despues de 10 o 15 minutos el robot se detiene en el mismo sitio aunque sigue subcionando y no continua si no es con ayuda
Hola,
Tiene un problema en el mecanismo que lo hace moverse de lado a lado de la piscina, con el timpo las ruedas responsables por su movimiento se desgastan, remplaze las ruedas.
Gracias
Jul 01, 2011 | Zodiac Pacer Pool Cleaner
My zodiac is pulsating, diaphragm is clean but it stays in one place>??
It sounds like you might need to adjust the pool cleaners water pressure. You need to use your flow gauge and check it. Keeping the hose submerged, attach the flow gauge to the hose and turn on the pump. Verify that the red indicator in the gauge (viewed from the side) is at the Number 3 setting. If you flow is low, verify that valves controlling the suction lines are in the correct position.
Oct 20, 2010 | Zodiac Baracuda G3 Automatic In Ground...
We found out tpday that we have 19 leaks in our inground pool liner which is not quite 2 years old!! The only thing we've changes this year is we purchased a Barracuda Robotic pool cleaner. Have you ever...
It will have a strong suction to the pool floor and could grind bits of sand into the liner. You might want to try a Arneson Pool Vac.
Be sure they put cork feet on it though so it goes easy on the liner.
If and when you replace the liner be sure to put an under-liner down first. This will help with problems that run along these lines.
Sep 13, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Can't adjust the chlorine output level of Zodiac LM3-15
Nost often it just needs to be cleaned. Calcium build up can clean in a tub of 1 Part muratic acid to 5 parts warter. or a 2 to 1 soultion of vinigar and water, otherwise it could be faulty. Cleaning typically works.
The Pool Tech
Jul 04, 2010 | Zodiac Nature 2 Cra30 Replacement...
Flips over
There is a float in the body of the cleaner that keeps it upright. Uour pool store will have this and can change it for you also.
Aug 02, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Does not clean the whole pool
may need to re-weight it or add helpers.
I had to add a rope system to my pool to get the creepy crawly to all the spots.
Not the best fix - but keeps the pool clean.
Apr 10, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Pool & Spa Logo
66 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
