JVC GY-HD111E Mini DV Digital Camcorder
Problem for JVC GY-HD111E Mini DV Digital Camcorder
My JVC GY-HD111E isn't located in final cut pro
By mbolton02 on Mar 28, 2009
I plugged in my firewire 800 correctly but final cut pro version 6.5 won't locate the device so I can't capture footage.
Solution #1
posted on Jun 26, 2009
Not Rated)
niallh1
Rank: Wiz
Rating: 78%, 12 votes
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Comments:
Jul 01, 2009
- I know it has worked. While video is playing in vcr mode - try unplugging it at both ends reconnect at both, then insert and remove it about 10 times quickly from the computer. Has it worked for you before? The driver may be worth downloading again.
Was this helpful?
Yes
No
Popular Solutions for JVC GY-HD111E Mini DV Digital
Questions and Unsolved Problems for JVC GY-HD111E Mini DV Digital
Do you recommend JVC GY-HD111E Mini DV Digital Camcorder?
Answer
Answer
I need a User's Manual for a Samsung HMX U10 HD (Green) Flashcam. Any suggestions for a PDF... (More)
Answer
My Canon MD205 won't charge up. All I had to do was plug in the charger and attach it to the front... (More)
Answer
how do i set the date and time on es8400 canon camcorder
Answer
Camera works perfectly with mains power, but won't turn on with battery pack. I have tried new... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC GY-HD111E Mini DV Digital...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 904
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
