Question about Whirlpool Refrigerators
What size is your model # GD5YHAXNL03? - Whirlpool Refrigerators
Comfortmaker 10 HVAC output size?
Comfortmaker 10 means simply it is a 10 SEER system. Unable to determine the OUTPUT size without the Model Number. Go to the Outdoor Unit Nameplate and locate the Model No. Here is an easy way to determine the "SIZE" of the "Comfortmaker 10 HVAC" Systems:
Model No.: OUTPUT Size (Nominal Tons of A/C):
NAC015 1.5 Ton Unit
NAC024 2.0 Ton Unit
NAC030 2,5 Ton Unit
NAC036 3.0 Ton Unit
NAC042 3.5 Ton Unit
NAC048 4.0 Ton Unit
Aug 30, 2014 | Heating & Cooling
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
How can I tell the size on a Hard Drive? It does not say the size on the label.
type the model number into google, nothing else and it will tell you the size, the size is also usually the first few numbers after the Letters of the model
Mar 17, 2011 | Maxtor Hard Drive
I own a yamaha g5 2009 model, i want to change the rear tyre, shall i go for a bigger size, tell me the size which i should go for?
Hi
Its best to stick with standard sizes as Yamaha put a lot of research into finding the best tyre sizes for each model
Ride Safe
Bike-Doc
Sep 29, 2010 | 2008 Yamaha Yamaha G5
Need to know the exact size of rims for a 2008 323i sedan BMW
2008 BMW 323i 4 door sedan - factory wheel rim size
Rim size (standard factory spec):
16 inch by 7 inches wide.
Front and rear are the same size.
(It is possible to fit 17 or 18 inch rims to the car if you wish together with an appropriate lower profile tyre ).
(please note that different models in the 2008 3 series BMW have different size rims. For example, the 328 and higher level models runs larger rim sizes).
Hope this helps. Cheers
Dec 08, 2009 | 2008 BMW 3 Series
Magnetic brush size
Yes and no. From 1999 to early 2008, excluding the slightly beefier "Ergo" models, the size / part number is the same. However, on the newest models there are differences in density between some models. Wire placement is different from the older models.
Sep 13, 2009 | Metabo WE14-150 Quick Angle Grinder
Tire sizes 1994 toyota corola
Tire Fitament:
Front and Rear Tires
Tire Size:
P185/65R14
Wheel/Rim Size:
14x5.5 inches
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 10, 2009 | 1994 Toyota Corolla
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
