Question about 3G Technology GM-171B 17" Flat Panel LCD Monitor
How to remomve the base of my 17" LCD Monitor Part #: GM-170B
Phillips 170B volume adjustment bar automatically pops up
Usually for the volume bar to just pop up something would have pressed the volume button. It is possible that the volume button has gotten a malfuntion on it and this makes it to pop-up all the time. Try getting underneath the volume button cleaned. But preferably this should be done by an expert.
Hope this solution has been helpful?
Jul 20, 2010 | Philips Business 170B 17" Flat Panel LCD...
I have a left-right blur on my Philips 170B monitor. Tried resetting several times, but no joy. Can you help? Thanks :-)
if u'r eng. change the crt base in video board or u'can set u'r defocusing prob by EHT focusing section
Dec 12, 2009 | Philips 170B4MG 17" LCD Monitor
Screen message reads "no video input",blue scart is connected at both ends,what have i missed? Pillips 170b monitor
Try another monitor with your computer if this still doesenty work then your graphics card is at fault
Nov 26, 2009 | Philips 170B4MG 17" LCD Monitor
Volume Control Bar does not go away
IN THE SETTING OF THE COMPUTER SOME WHERE IN THE SETUP OF THE COMPUTER YOU CHECK A BOX NO ON PERPOSE JUST BY ACCENDLY PICKING IT AND NOT UNDERSTANDING WHAT THEY MENT IN THE BOIS, INTER NET OPTIONS OR YOU MAY HAVE TO GO INTO THE BOOT LOG AND UNCHECK THE BOX FOR BOOT SEQUENCE SETTINGS,SYSTEM CONFIGURATION, BOOT OR STARTUP FILES
REBOOT SYSTEM YOU MAY HAVE TO DO THIS SEVERILY TIMES
ROD
YOU MAY HAVE REGEDIT
IF YOU NEED THAT TYPE OF ASSISTANCE I MAYBE ABLE TO HELP YOU BUT I PERFER YOU GO TO SOMEONE THAT DOES COMPUTER PROGRAMMING
ROD
Feb 09, 2009 | Philips Business 170B 17" Flat Panel LCD...
Monitor
sound like the power supply or the monitor bulb is going.
try the monitor on another PC if you can get one, if it works, then you have to find ou the manufature of the video card and get the driver.
Nov 05, 2008 | Philips 170B4MG 17" LCD Monitor
Computer says disk boot failure when I turn it on.
hard drive failed or you have a cd in or floppy in the drive.
Jan 07, 2008 | Philips 170B5CB 17" LCD Monitor
Philips 170b 17" LCD Monitor
Does the screen go to the top of the page by any chance if so their is a possible cable problem that links your PC to your monitor, to repair this you must take it to a electrical repair shop, its quite a small job and your screen should be back up and running in no time, it happened to my packard bell monitor aswel and i managed to get it repaired.
Hope this answers ur question John.
Nov 21, 2007 | Philips 170B4MG 17" LCD Monitor
Philips 170B lcd monitor
Crackling sounds are probably due to a couple of capacitors failing due to age, on the control board. (They can also "whine"). Should be easily replaceable by any experienced technician. Not a difficult job.
3G Technology GM-171B 17" Flat Panel LCD Monitor Logo
42 people viewed this question
Top 3G Technology Computers & Internet Experts
William Miller
William Miller
Chris Larocque
Daniel Quinn
Daniel Quinn
Are you a 3G Technology Computer and Internet Expert? Answer questions, earn points and help others
