Question about Toys
Nexus helicopter V789 does not charge
Almost brand new helicopter , tried out once then stopped working. when got home it would not charge to my computer or wall plugin. Took it back to the mall seller and he flew fine but when I tried it at home it would not charge Cables seem to be connected as I took the top off. no lights go on
4 Suggested Answers
  • 23 Answers
SOURCE: my helicopter wont fly
either stripped the main gear inside the heli or the main blades where they slide on the shaft. you should be able to buy a replacement set of blades. try that and see if it'll fly.
Posted on Apr 04, 2010
SOURCE: I can't seem to charge
You should see the orange LED glow when you first plug the cable in. Once you plug the heli in, the LED should go out. Once the heli is charged, the LED will come back on.
Posted on Mar 09, 2011
SOURCE: My new u-control helicopter is experencing spinning
I had the same problem, the helicopter would spin out of control and the trim did not help. I took a closer look and noticed that only the top rotor was turning. I took the bottom off of the round gear box to find a tiny white gear had slipped off the second motor. With a pair of needle nose tweezers I was able to reattach the gear and I was flying in no time.
Posted on Feb 02, 2012
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Hello, I bought the fusion rc helicopter and I
If the battery does not recharge either it or the charger is defective.
Feb 22, 2018 | World Tech Toys GYRO Fusion 3.5CH Electric...
Volitation 9053 flashing green light when charging brand new out the box
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Nov 17, 2011 | xheli 9053 Outdoor Volitation Metal...
Syma S032 Transmitter battery lights blinks even when Brand new Alkaine Batteries are fitted
0) Obviously, helicopter will operate best when fully charged... if charging light gets brighter when unplugged from helicopter, then it's not at full charge. Charge fully, then allow battery to cool for 10 minutes. Good batteries in remote also.
1) Power on helicopter.
2) Place on level surface and let gyroscopes sync. There is a red light inside the body (NOT the red/blue flasher in the nose) that will blink when you turn helicopter on, and will keep blinking until craft is level and stable for a few seconds, then will stop blinking.
3) Make sure left joystick is all the way down.
4) Power on remote.
5) Throttle up (left joystick) until blades move and then all the way back down.
This should get you flying. Let me know
r
Jul 30, 2011 | SYMA Toys industrial Syma S032 Ready to...
I can't seem to charge my S107 helicopter. I plug the USB charging cable into my computer, and then the helicopter itself, but have no indication that it is charging. Should I see a light on the...
Jan 01, 2011 | SYMA Toys industrial New Syma S107 Radio...
I just got an r/c helicopter ( gyro s032 ) i've just tried it once but then i tried charging it for second run, but when i plugged the charger cable in the helicopter. It din't want to charge,i looked,and...
couple of things possible. 1) change outlet. 2) call customer service for the helicopter (should be on manual in contact section) 3) the helicopter has a loose cable connected to the battery inside the helicopter so you probably need to sodder it.
Dec 26, 2010 | SYMA Toys industrial Syma S032 Ready to...
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
I have a brand new Syma model S031G model toy helicopter. I have no instruction manual. It has been charged and the lights work. My remote has new batteries. But it will not make the blades rotate. Can you...
Looks like a board circuit problem. If its new, you have to return it and replace it with another one, try it before going home.
Try this, open the board, there are two trimming resistor adjustment, one for the rear motor and the other one controls the main motor, try to adjust it while your switching the remote controller to lift.
If that does not work. The little servo on the board are busted and you need to return the product!
Thanks for using Fixya!
Dec 15, 2010 | xheli Syma S031 Outdoor RC Helicopter
Toys Logo
611 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
