Question about Nelson Sprinkler: Traveling Tractor
Parts model #42327
Part is broken that holds wand sorayer
The turbo wand and nozzle connection on my Pressure washer Model 580.752070 How to restore seal between Wand and nozzle? Please point me in the right direction to resolve this problem
the seal is normally a "O" ring that is available from a good hardware shop or bearing supply shop
basically the same set up as your garden hose "O" ring but with a pressure wand there is a thread nut to hold the bits together.
If it is not that then the threaded section of the connection in the wand or hose mat be loose or broken at the thread
Jun 12, 2015 | Garden
Hi my front and rear window washers aren't working checked fuse it's ok what else could the problem it's a 2005 discovery 3
could be a broken hose if so it would be soraying on the ground is the pump running, or is it frozen
Feb 24, 2015 | Cars & Trucks
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Looking for clips for the bissell 1631, need the clips that hold top to tank and clips that fit on wand and hold hose to wand. m9egm@hotmail.com
you can try to order the parts from Hesco. you can google Hesco in the search engine and look up your model number. here are 2 that i have found. some of the parts that you are looking for are no longer avaliable.
BI-2135512.
.BI-2135520
Oct 11, 2009 | Vacuums
Brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
The clip that holds the EL5 powerhead to the wand has broken (again). How does one fix this?
i found this part online- search for part # via an exploded parts diagram of your specific unit (via google)
i ordered 5 of them because it always breaks or pops out.
this is a nice machine with crappy parts.
sorry :(
May 03, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Need parts for Wand
yes go to Northern Tool supply Lowe's or HomeDepo any of these places should hace what you are looking for
Feb 02, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Cannot disconnect the wand from the power cleaner
Looks like you will have to replace the quick disconnect asm. part # 38646086, you should be able to order this thru a shop that repairs Hoovers. If this is less then 1 year, then it is under warranty. You can call Hoover's 1-800 #. should be in your owner manual and on the metal tag on the cannister to find out where you can get part.
Oct 31, 2007 | Hoover S3765-040 WindTunnel Bagless...
Nelson Sprinkler:  Traveling Tractor Logo
116 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
