Question about Car Audio & Video
Removal of gas tank on a 1988 mercedes benz 300se
I have already removed the trunk cover, now what do I do
  • 98 Answers
SOURCE: drive belt diagram 1990 300se mercedes
I know it's a little large, but here's the belt routing diagram you are looking for. Hope it helps!
Posted on Nov 23, 2008
  • 84 Answers
SOURCE: 1988 Mercedes Benz - 300E , want to replace window switch
Hello, To the rear of the wood grain where the switches are, you should have a small piece of carpet that you just pull up and get it out of the way. You should see 1 screw. Remove the screw and gently pull up on the back of the wood grain. Now you will be able to change the switch.
I hope this helps.
CYA, Gator241
Posted on Feb 07, 2009
  • 11 Answers
SOURCE: replacing the battery in a 2001 mercedes benz
Battery base has a device that clamps the battery on a step/notch on the side. Use a ratchet with an extension to loosen. Once it is loose you can remove the battery.
Posted on Apr 03, 2009
  • 1619 Answers
SOURCE: How do I remove the door panel on a 1995 Mercedes
pull off rear mirror panel, pull off electric seat adjuster knobs, pull off plastic around door handles. Unbolt top of handle. Pull out light at bottom of door. Unscrew plastic stiker plate and remove. Unscrew lock knob to remove. Then your ready to wiggle and pull the panel up and off, be careful of the area around the door handle, you may even want to pry that area out before you begin.
Posted on Apr 13, 2010
  • 1619 Answers
SOURCE: How do I remove and replace the radio in a 1993
First thing is to understand you will most likely have to run all new speaker wire as the head unit in your car has everything external to the head unit (power amplifier, fader). The plastic around shifter pulls up off, then remove wood surround. Remove ashtray, pull face off head unit usually by sticking fingers in cassette area and pull. There will be plastic tabs on the bottom of unit push in and pull out on head unit, pull slowly so you can inspect wires for placement. Again rerunning speaker wire should be done to preclude external amps and fader switch and power antenna if yours still works.
Posted on Jun 05, 2010
Testimonial: "Thanks so much. This is very helpful!"
Low idle on 1992 300se
clean your idle control valve will be dirty and sticking.
Mar 11, 2014 | 1988-1993 MERCEDES BENZ 300CE 300 CE...
1991 300SE mercedes wont stay running
Check Fuel Pressure first, then Fuel Pressure regulator, and then your ETA(Throttle Body) Insure that you also do not have any Vacum leaks anywhere whatsoever. Your problem could be small or big but be patient. I have a 92 300SE I know it can be fustrating to you, Let me know what you find out.
Feb 01, 2013 | Bosch 1991 91 Mercedes Benz 300SE...
Vacuum Diagram for Mercedes 300se
Hi I can take a picture of mine and send it to you if you want to try that I had similiar issue after having some repairs and they didn't reconnect them correctly so I followed my diagram, However I am having some start, stall issues and my mpg guage is reading 10 mpg while at idle is this something you know of ?. let me know if you still need photo of diagram of 92 300SE
Aug 27, 2012 | Bosch 1992 92 Mercedes Benz 300SE...
Need instructions to install brake light switch on a 1988 mercedes 300se Thanks
The brake light switch is located behind the brake pedal. pull driverside underdash panel off. After locating the brake light switch just depress the tab on the side, turn, and remove. install in reverse order. to set clearance gap of brake lamp switch before installing into vehicle. push travel rod all the way in and pull out 5 clicks
Oct 01, 2010 | Mercedes-Benz 300-Class Cars & Trucks
My gas gauge wont register
this problem is caused by a defective gas gauge sending unit, the sending unit is located inside the gas tank, check in the trucnk for an access plate, look under the trunk carpet area over the tank, if no access is found the fuel tank must be removed to replace the sending unit.
May 14, 2010 | 2007 Mercedes-Benz C230 Sedan
Need to find the fuel pump for a 1989 mercedes benz 300e
that particular model has an external fuel pump
is located underneath and if you take the rear driver side wheel you will get to it easier but not if you are going to replace you fuel pump replace the fuel filter also or otherwise the new pump will not last.
and have a large container handy because wend you take the fuel pump off. you will spill a large amount of gas .
the tube going from the pump to the gas tank in on the bottom of the tank and will spill all the gas in it unless you move quickly.
Jun 29, 2009 | 1989 Mercedes-Benz 300-Class
Car was hit from behind I need to know If I can get in the trunk through the back seat? 1992 Mercedes-Benz
I am not that familiar with the gas E class of that year but in the diesel you can not get to the trunk through the back seat without removing the gas tank which is upright between the trunk and the back of the car. It would make sense that the gas model would be the same design.
Danny
MB300dt@yahoo.com
MBCA- South Jersey Section , Secretary
Apr 16, 2009 | 1992 Mercedes-Benz Mercedes Benz 300 Class
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
