Question about Conair Health & Beauty
Scherna hair clipper head reassembling - Conair Health & Beauty
SOURCE: conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
clipperdoc
  • 17 Answers
SOURCE: Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Posted on Nov 14, 2009
  • 5 Answers
SOURCE: OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Posted on Jan 07, 2010
SOURCE: How do I use Wahl hair clippers? How do I know
Hi I have been a hair stylist for 25 years each guard that clips on has a number on them the lower the number the more hair is clipper off start big like a number 8 will leave one inch of hair 7 leaves 7/8 of a inch 6 leaves 3/4 of a inch 5 leaves 5/8 of a inch 4 leaves a 1/2 inch of hair on the head 3 leaves 3/8 of a inch 2 leaves 1/4 of a inch and a 1 is just hair on the Scalp almost bald no days the color of guards are changing so your best bet is go with the size remember to start with the largest one first then you will know what you like the best and you can't go wrong and if you buy WAHL and you not A Hair Stylist You Can Purchase A Good Clipper at Sallys Good Luck
Posted on Jul 30, 2011
SOURCE: I was shaving my dog
With most clippers, after an amount of use they need to be cleaned then oiled. Most sets come with some amount of oil for your clippers. Otherwise you can purchase it separately. This should fix the problem.
Posted on Aug 25, 2011
Jul 30, 2011 | Wahl Health & Beauty
I used the clippers to cut my dog... once finished I took it apart to clean out excess lubed parts and reassembled...I have done this many times before with no problems... I begin cutting and the blades...
Check your blade latch is working properly. If you took your clipper apart and your blades are not cutting it is one of 2 things. Your blade drive is not assembled properly or your blade latch is not holding the blade on the clipper. If you took your blade apart, check the blade alignment. The cutter blade needs to be slightly behind the comb blade.
Mar 11, 2011 | Andis AGC2 Hair Trimmer
I have an A5 clipper, with three blades. I have had difficulty with this clipper, ever since I bought it. I have a schnauzer with very fine, soft hair, a bouvier, with very thick hair, and a Lakeland...
hi, on some ocassions when the clippers get hot the metal gear shaft moves meaning the movement of the clipper is limited, you can remove they gears in the gearbox when its hot and see if there is any side to side movement.
Nov 26, 2010 | Oster Golden A5 2-Speed Universal Motor...
New clippers
what type of hair clipper are you looking for. mannyssharpening.com has very good warranty they fix what they sell
Sep 26, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Clippers jam and won't cut when trying to use attachments
OIL THE CLIPPERS AND CLEAN THE HAIR OUT REALLY GOOD.
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Conair hc318d reassembly
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Health & Beauty Logo
60 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
