Question about KitchenAid Dishwashers
Kitchenaid kuds30ivwh2 cycle lights on all the time, not bright
MY KITCHENAID DISHWASHER FAILS TO POWER OFF
Programmer fault.......time for repair man or replace machine. I assume out of warranty.
Jul 21, 2014 | KitchenAid 24 in. Built-In Superba Series...
KitchenAid KUDS30FXSS Dishwasher won't complete cycle
Press the Cancel/ Drain cycle for a few seconds. The dishwasher should reset itself. See if this makes any difference. Also first turn the mains power to dishwasher off and back on.
Apr 13, 2014 | KitchenAid KUDS30FXSS Builtin Dishwasher
KITCHENAID DW KUDS30FXSS - 18 months old, will not complete cycles. Runs for 15 mins and stops & lights go out. Cleaning tablet often left in dispensor.
See my problem and solution. Sounds like you, too, are having a problem with the main control board (computer chip that controls the dishwasher), which is apparently a common problem with this model dishwasher. The part can be found here, for $211 (tax + shipping), and they have a 30-day return policy in the event that it does not fix the problem. It's an easy DIY fix. Hopefully this helps!
Aug 15, 2012 | KitchenAid KUDS30FXSS Builtin Dishwasher
Kitchen Aid Artisan 2 slice toaster, model 5KTT780 Blue light comes on but not as bright as usual, elements don't heat up.
Try pacific8's answer to this problem with another KitchenAid toaster, especially the comment on that answer by pacifics pam, all found here: http://www.fixya.com/support/t9655297-toast_will_not_stay_down_in_toaster_when
Jun 08, 2011 | KitchenAid KTT780 2Slice Toaster
Loud noise accompanies commencement of each wash cycle ... rumbling very loud, laboring type noise. any ideas??
Hello- If the noise has been getting louder each time, then motor has most likely failed. Can be confirmed by pulling kick panel and looking underneath unit with a bright flashlight. Telltale water deposits on lowest point of motor case will confirm. Replace motor yourself for about 100$, or service call/part 200$. Let me know if this info helps. Have more if needed- Thanks- Ed
Mar 12, 2010 | KitchenAid Dishwashers
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 07, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Microwave stopped heating, evenything else works
Jan 03, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Dishwashers Logo
18 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
