Question about Proview PL713S 17" Flat Panel LCD Monitor
Beware this monitor! PL713s
This monitor just bit the dust on us! We just bought it a year and a half ago, and we started experiencing a flashing screen, lines looking like bar codes, etc. Then the monitor completely lost power. Stupid us, we didn't get the extended warranty. We called Proview customer service and were told it was our video card, but that was not correct. Bottom line, I don't think problems with these monitors are fixable. The only solution we found was to go buy a new one:(
  • 63 Answers
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. www.tigerdirect.com www.newegg.com Good luck
Posted on Aug 27, 2007
SOURCE:
My belkin wireless router (black with silver base) I bought from iinet over two years ago is flashing the internet and wireless light. I dont know why. I am also experiencing intermittent slow speeds. The...
It sounds like a wireless device on your network is cheap king for updates every 30 minutes. When your wireless light flashes, it means a wireless device is talking to your router. When your internet light flashes, it means your router is talking to the internet. It is normal for both to flash at the same time. If a wireless device is downloading an update, then the speed will slow down for other devices. I hope this helps.
Jan 08, 2018 | Computers & Internet
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Belt broken on bosch rotak34 lawn mower i wish to strip it down and replace belt
OOOOH NO BOSCH PEOPLE WHO READ THIS QUESTION i know we are a few years later but that have bought for a few years ago English qualcast tools was taken over by BOSCH Beware of the high tension behind the pully of all Wear safety goggles. if the motor is split do not tension on a half open motor because the bearing in one site of the pulley breaks by the to high tension the motor parts must first be brought together both half parts and the belt between that must be tensioned by a good long piece like a very great screwdriver inside the great pully to tension the belt on the pulley , !!! a hell of a job .
Jul 25, 2011 | Bosch Tools & Hardware - Others
Have HP slimline series. Came back from a break.
Try another monitor on it to verify it is the video card that has gone bad. If it does not work with another monitor then that is the likely culprit.
May 06, 2010 | Computers & Internet
I had the same exact problem.
First power up the computer then press F8 key then if you see safe mode and other menu then enter in enable vga mode then go to control panel and change screen resolution to 1024*768.
If you can;t see safe mode and other menu.
Then open the cpu cabinet then refix RAM memory .
clean dust from circuit and RAM.
Pull cmos cell from motherbord for 15 minutes so all bios settings are defaults.
Then check.
Aug 01, 2009 | Acer AL1916W 19" LCD Monitor
Dust stuck under glass on the lcd screen of my d60
If you purchased your D60 new, you could sent it in to Nikon for cleaning but personally, I'd wait a while if it's not affecting the camera's functions. If you need warranty work within the first year, you can send the camera in for that work, and they'll clean under the LCD while servicing the camera.
May 31, 2009 | Nikon D60 Digital Camera
My proview PL713s will not display an image!
I'm having the same problem. Did you ever figure what went wrong?
Aug 02, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
MONITOR CONTRAST OR COLOR
find on the net an adjust software (eg. Nokia test), it helps you on dealing the problem...
Jul 12, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
88 people viewed this question
Top Proview Computers & Internet Experts
 Mike M
Mike M
Siul Oyaratgam
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
