Question about Samsung Digimax S730 Digital Camera
HEEEEELP i think the battery might be low, but i changed the batteries and it still wont connect to the computer (it will hook up but when i press "on" it wont go on) PLEASE HELP IF POSSIBLE
  • 20 Answers
If you don’t find a solution you may want to try [email protected]. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
Posted on Sep 14, 2008
SOURCE:
My mini harrly bike won't start. It is just making a clicking noise on the left side of the back as u sit on it. I think it might b the relay but not shore. Please help...
Could be starter or might be dirty battery connection or loose battery connection. While trying starting tapping on starter might start if it does change starter.also check voltage from battery. Charge battery if battery wont chare check level of battery if low use distilled water in battery and fill. And charge over night if this doesn't work change battery. Hope this helps you
Aug 24, 2014 | Motorcycles
How can i know if my starter relay is bad on a dodge stratus 2001
IF STARTER RELAY BAD THE STARTER WONT MAKE NO NOISE AT ALL HEADLIGHTS WONT DIM.IF YOU CLICKING NOISE BATTERY VOLTAGE TOO LOW. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS AND USE TEST LIGHT TO SEE IF STARTER GETTING POWER.COULD HAVE BLOWED IGNITION FUSE OR FAULTY IGNITION SWITCH. TO CHECK STARTER SOLENOID FIRST TURN OFF RADIO THEN REMOVE NEGATIVE BATTERY CABLE AND POSITIVE BATTERY CABLE.THEN REMOVE STARTER BUY A REMOTE SWITCH.YOU NEED BATTERY JUMPER CABLES HOOK BATTERY JUMPER CABLES TO BATTERY PUT POSITIVE CABLE ON POSITIVE BATTERY POST THEN PUT NEGATIVE BATTERY CABLE ON NEGATIVE POST. HOOK BATTERY CABLES TO STARTER USE NEGATIVE CABLE GROUND STARTER BODY AND PUT POSITIVE BATTERY CABLE ON THE LARGE POSITIVE POST ON STARTER SOLENOID. NOW TAKE REMOTE SWITCH HOOK RED WIRE TO STARTER SOLENOID POSITIVE POST THEN HOOK BLACK WIRE TO REMOTE SWITCH TO STARTER SOLENOID SWITCH TERMINAL WITH LETTER S THEN PRESS REMOTE IF STARTER SPINS STRONG WITH A GOOD KICK STARTER GOOD.YOUR PROBLEM COULD BE CORRODED WORN BATTERY CABLES. WEAK BATTERY FAULTY IGNITION SWITCH. IF STARTER DONT WORK WHEN YOU PRESS THE REMOTE SWITCH STARTER SOLNOID BAD OR STARTER ITSELF BAD.IF ALL IS GOOD. CODE SCAN CAR FOR THEFT SECURITY FAULT CODE.
Aug 28, 2011 | 1999 Dodge Caravan
All lights stay lit on my CD changer when I turn off engine and remove key in my 2006 Maserati. Battery went dead, I think, because of this. One person who came to change battery said that when the...
the lights might be staying on because the remote wire is hooked up to the 12 volt constant or battery wire instead of being hooked up to the ignition wire.and i have never heard such a thing of when the battery gets low the computer can cause the lights to stay on that is BS. I hope I have answered your question.
Aug 02, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
My mp3 player doesn't turn on even if I charge it. Do you think I need a new battery?
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, to switch the player to MSC mode
1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Skip this step if you think it is charged. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 30, 2010 | SanDisk Sansa m230 MP3 Player
My sandisk sansa clip 1gb wont turn on
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
How do i hook up my ps3 controller? It's not working!
probably battery is low, try connecting the controller to the usb port for an hour and press the home button and it should connect.
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
Wont Charge
Yeah, I had this problem too because I was connecting the USB proprietory connector/cable at the front USB drives on the computer. If you have been using front USB connecters, try using the back USB drive connecters.
It worked for me :)
Apr 12, 2009 | Sony NWZ-E436F MP3 Player
I need help with my sansa e250..thnkx.!!
I think maybe it isnt connected to the computer corectly because it should go to the connected screen. try hooking it into the main USB ports.
Jan 17, 2009 | SanDisk Sansa e250 MP3 Player
Not again wont turn on
i had the same situation this happens when you dont turn off your t20 after you disconnet it from your pc IRIVERS T2O PROBLEM IS THAT IT AUTOMATICALY TURNS ON EVERY TIME YOU DISCONNET IT FROM PC AND IF YOU DONT TURN IT OFF AFTER THIS - IT FROZES it wont connect to pc after this happens so you have to wait ussualy (~12 hours) until the battery runs low, so after this has happened wait and then after some time try to press play button (to turn it on) and if the battery is dead - it will show LOW BATTERY sign and then you can connect it to your pc again normaly! hope this will help
Feb 28, 2007 | iRiver T20 MP3 Player
Samsung Digimax S730 Digital Camera Logo
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
