Question about Nokia 1100 1101 1108 1110 1112 1200 1208 1255 1315 1600 1650 2112 2118 2255 2270 2272 2275 2280 2285 2300 2310 2355 2600 2610 2626 3100 3105 3110 3120 3125 3600 3620 3650 3660 6030 6085 6086 6108 6230 6268 6270 6282 6600 6620
Hdmi DVD player
There is no hdmi outlet on the tv. Does this mean this tv is only compatible with old DVD players? Is there such a thing as a hdmi converter that would allow me to use a hdmi DVD player with this tv?
    Top Expert:
  • 12,223 Answers
Normally all new tv as port HDMI, if you do not have you need a converter see the diagram attached.
Posted on Jul 11, 2013
How do I get it to hook up to my tv and get it to play dvds
There will be a HDMI or Scart outlet on the back of the player. Plug this into the same on the TV, turn on and find the relevant channel on the TV and it should be working.
If you don't have the same inlet on the TV as the outlet on the player (i.e.only HDMI on player and no HDMI on TV) then you will need to use some kind of adaptor.
Sep 26, 2015 | Televison & Video
I have a Toshiba tv that is connected to Direct tv and I want to know how to connect my new Phillips dvd player to it my tv?
Flat screens normally have 3 different inputs from tv. Regular is tv coax cable, then audio/picture by using special rca cables, then last HDMI. You can use any of those inputs except hdmi because you already are using that input. You may be able to buy a hdmi splitting device that will allow both the tv and the player to input to the single hdmi input. Check Radio Shack or Wal-Mart.
May 12, 2014 | Toshiba HD-A30 HD-DVD Player
Dvx583kh no sound HDMI
you must read your instrc.manual from TV +DVD about the connection is compatible. or some connection is wrong. download your instruction manual go www.fitness.manualonline.com or www. retrevo.com
see the diagram connection
God bless you
Jul 13, 2012 | LG DVX583KH Player
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    Aug 13, 2011 | Panasonic Televison & Video
    When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
    you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
    Jul 11, 2010 | JVC TH-G30 Theater System
    My HDMI connection does not work with Blu Ray DVD player. I have tried a Sony (BDP - BX2 ) model and Samsung (BD-P1590). It could not even display the Home screen for the Sony. The Samsung played for 1 day...
    After reading your post a couple of times, it just seems your are in a little of a pickle here. The only thing I can suggest, since your tv will work with fios and not the your BD player(I assuming your using the same port on the tv with the same hdmi cable), is all about firmware. Maybe your tv is not compatible with the the BD player. Try updating the firmware on the tv.
    Dec 30, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
    TV does not always recognize the DVD player
    that's a firmware problem where your tv's firmware does not handshake with your dvd's firmware. This could be from your dvd's software being to old for your tv to understand it. HDMI (TDMS Technology) still has Alot of catching up too do with 3rd generation tv's. Alot of HDMI devices still have the first gen software loaded into them. So a tv after 2005 won't work with HDMI from 2003 (1st gen). Most tv's made after 2007 have software that's "backward compatible" so they will work with first gen HDMI.
    How does your tv perform outside this problem???
    Feb 10, 2009 | Samsung PN50A550 50 in. Plasma TV
    Hdmi Issue
    Most new HDMI DVD players use High-bandwidth Digital Content Protection (HDCP)on the HDMI output.If you try to play this on an older TV that is not compliant with these new standards it will not work.This standard came out late in 2004 that is why your older player still works. There is also a service bulletin from JVC about upgrading the software on your TV for HDMI compatiblity issues.If you want a pdf file of the bulletin I can send it to you.
    Sep 11, 2007 | JVC HD-56G886 56" Rear Projection HDTV
    Nokia 1100 1101 1108 1110 1112 1200 1208 1255 1315 1600 1650 2112 2118 2255 2270 2272 2275 2280 2285 2300 2310 2355 2600 2610 2626 3100 3105 3110 3120 3125 3600 3620 3650 3660 6030 6085 6086 6108 6230 6268 6270 6282 6600 6620 Logo
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
    IT Solution
    IT Solution
