Model# jss20-48ams timer relay
How do I operate this time relay? It is used on a Chinese plate heat press used for Sublimation. There are four windows that can be set. From left to right:the 1st two read numbers 1 thru 9. The 3rd reads "H", "M", or "S". and the last window on the right reads 0 thru 9(in red numbers). The press was given to me without a manual...PLEASE HELP!
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
brainyass
  • 242 Answers
SOURCE: morphy richards electric blanket - how to use timer setting
Go here and pick your model for instructions:
http://www.morphyrichards.co.uk/DownloadSearchResults.aspx?G1=G19
Posted on Oct 24, 2008
SOURCE: Re: HP 1320 won't take the tray designation for 2 and 3 Help
Hello classygirl,
I had this exact same problem and resolved it by downloading the HP LaserJet 1160/LaserJet 1320 North American and Western European Full Printing Solution which can be downloaded from support.hp.com.
Because the 1320 does not have a built-in interface, installing the basic drivers will not work. You must download and install the full 400+mb package.
Hope this helps!
Posted on Jan 06, 2009
colliewob
  • 781 Answers
SOURCE: BOOT.INI default=signature (78c2dcdc)disk(0)rdisk(0)partition
I think the hard drive has no operating system on it or the MBR :Master Boot Record" is corrupt.
Try downloading "Hirens Boot CD" and burn to cd and boot from it.
It has a lot of useful Utilities on it for restoring MBR and formatting and partitioning
Posted on Jan 29, 2009
What is the meaning of sublimation heat press?
Its a heating device that is used for putting heat transfer on to articles
example putting logos or transfers onto cups
Not my expertise but i am sure its correct
Hope it helps
Apr 21, 2017 | Coffee Makers & Espresso Machines
What does E61 service call on my frigidaire affinity mean???
read the whole manual no code e61 ?
READING ERROR CODES
1. Rotate cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position. The four indicator lights of Drying, Cool Down, Wrinkle Rid
(Press Saver), and Clean Lint Filter will flash the number of times for the first digit of the code and the START indicator
light will flash the number of times for the second digit. Take separate counts of each indicator light, then repeat to
confirm in order to be accurate in identifying the proper error code. The code is obtained by counting the number of times
the lights flash. Example E24: The four indicator lights would flash twice indicating the 2 and the START indicator light
will flash four times indicating the 4. The four indicator lights and the START indicator light start flashing at the same
time. The control will pause for 2 seconds, then repeat the code.
NOTE: A letter appearing in the code stands for a number higher than nine. A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. The four indicator lights would blink four
times and the START indicator light would blink ten times. Troubleshoot the problem by using the chart below.
To move on to the next code, press the OPTIONS button.
To clear code, press the Select button. Code will be cleared when mode is exited.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Error Code Label Description Solution
E10 General EEPROM
Fault
Problem with communication
between EEPROM and the
microprocessor.
Clear code, exit mode and start dryer. If problem persists, replace electronic
control.
E11 Checksum Error Problem with communications or
memory did not check, one has
become corrupted.
control.
E12 Non fatal R/W
error
Problem reading or writing to the
memory or input/output.
control.
E24 Control NTC Short
Circuit
Control thermistor or its wiring is
shorted.
Remove wires from control thermistor. Measure resistance of thermistor. If
reading is not 50 K (± 10%), replace thermistor. If reading is within 50 K (±
10%), check wiring between thermistor and electronic control. If good,
replace electronic control.
E25 Control NTC Open
Circuit
open.
E4A Program Timeout
Fault
The drying time has exceeded
program time for that cycle.
Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes.
Position cycle selector to NORMAL, temperature selector to HIGH HEAT
and touch START. Check for anything that would extend dry times such as:
no heat, restricted vent, blower fan blade broken or loose, dryer installed in
closet with solid door, or bad connection in moisture sensor bar circuit or
dirty bars. If dryer operates normally but code returns, replace electronic
control.
E5B Heater Fault (no
heating)
Temperature reading of control
thermistor has not changed in a
certain amount of time.
and touch START. Measure voltage across terminals on relay RL2 (heater
relay) on electronic control. If meter reads 240V on electric models and
120V on gas models, replace electronic control. If meter reads zero, remove
power from dryer. Disconnect wire going to NO terminal on the relay RL2.
Reconnect power and measure voltage drop between terminal COM on
relay RL2 and neutral. If meter reads zero, wire between incoming line and
relay RL2 is open. If meter reads 120V, check the rest of the heater circuit.
E68 Key (button) Struck
Fault
One of the keys (buttons) is stuck
closed (active).
Enter function test mode and perform key (button) test to determine which
button is at fault. Carefully free the and perform the test again. If button is
free but the key struck code still exists, replace electronic control.
E8C Too many trips in a
period of time.
The safety (high limit) thermostat
has tripped too many times within
a certain period of program time.
Check for blocked lint filter, blocked exhaust, air leaks around air duct,
broken blower fan blades, worn or loose drum seals, dryer installed in closet
with solid doors or door seal not correctly seated.
EAF Watch Dog Reset Microcontroller has been reset by
internal Watchdog timer.
Jun 14, 2014 | Frigidaire Electric Dryer
What does E6 error code mean
here is basic error codes for your dryer (and how to get them out)
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
Jun 04, 2014 | Frigidaire Dryers
WHY DOES MY DRYER KEEP SHUTTING OFF WITH BLINKING LIGHTS
sure is heres how to get the fault codes
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 09, 2014 | Frigidaire Dryers
Frigidaire affinity dryer yes code
heres how to get them :
READING ERROR CODES
E10 General EEPROM
Fault
microprocessor.
control.
become corrupted.
control.
E12 Non fatal R/W
error
control.
Circuit
shorted.
Circuit
open.
E4A Program Timeout
Fault
control.
heating)
Fault
closed (active).
period of time.
May 06, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Cloths are not drying in one cycle and need to extend the time of the drycycle not sure how? Model no dcd330gy1wc
Hi demetriosqat...
Sounds like you have a Clogged Vent or Heating Element problem.
Heating Element
Cycling thermostat
Please take time to rate me thumbs up.
Sep 10, 2011 | Dryers
Kenmore dryer...model # 1108262101 clothes not getting dry...normal dries better than perm press but still not as good as before....where do I begin? Thanks, Mary
Hi lkyldy31...
Your dryer is acting like it has a Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 22, 2011 | Kenmore Dryers
I purchased a twinbridge chinese pen tablet software years ago. After a period of time I found it again and intalled into my another PC, but when I insert the tablet plate (USB) into the PC, the mouse...
This is a driver problem. The tablet worked fine on the first computer as it was probably Windows XP and the computer you are trying to use the tablet on now is a Vista or Windows7 pc. You need to go to the Twinbridge Chinese Pen Tablet web site and click on Support, then Downloads. Then put in your Model number and download the driver for your operating system; Win7, Vista, XP, Linex or Mac Os.
Oct 13, 2010 | Computers & Internet
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
148 people viewed this question
k24674
jasbo
jasbo
