Question about Microwave Ovens
Model-409YVA I BOUGHT A SHARP MICROWAVE YESTERDAY AND GOT IT HOME ITS NOT HEATING IS THERE A BUTTON OR SOMETHING I NEED TO CUT ON
SOURCE: regarding microwave
Dear Sir/Mdn
My microwave is running but not heating food,model R-248J(S),S/No: 070737958,I hopw i will get better solution ,thank You.
Aung Aung
HP: 65-90468925
Posted on Apr 12, 2009
ginko
  • 19396 Answers
SOURCE: Sharp Microwave stopped heating
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
The diodeand capacitors can be tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, evenif power is off.Capacitors can get discharged by shorting their two contacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Posted on May 16, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp carousel microwave, Model Number R-1505F, is not running
This is usually caused by either a bad bottom door switch or a loose bottom door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
See http://www.microwavedisplay.com/doorsw.txt
If you only need a switch, you can order a universal type here for $5 postpaid.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller
prototech@usa.net
Posted on Aug 30, 2009
  • 136 Answers
SOURCE: I heard a pretty loud pop on my Sharp R-1505
get rid of it your transformer blew out they are to costly to replace and potintialy dangerous to work on unless you are trained technican
Posted on Oct 08, 2009
SOURCE: Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Posted on Sep 01, 2010
Magnetron part for a sharp carousel Microwave oven Model R-930ak
Maybe a faulty magnetron but check for abnormal noise caused by faulty diode pack. If you are in UK google the part number
RV-MZA114WRE0
R930AK Sharp Sharp Microwave
Apr 07, 2017 | Sharp Microwave Ovens
Sharp carousel model r-409yva
You may be using a cup or container that is not compatible with your microwave oven.
Jan 17, 2014 | Microwave Ovens
The microwave oven has completely gone dead Sharp r-1501c. Yesterday the light was on. I went to turn the light off and to put something in the microwave and it lost all power. I've checked the outlet...
It may be the control panel. What ever you do, don't send the control panel to William Miller. He ripped me off, and I have to dispose of my microwave because he never returned my control panel.
If yours has gone dead completely, it's more cost effective just to replace it. I bought an LG to replace mine.
Mar 08, 2011 | Sharp R-1501 Microwave Oven
Bought microwave but no manual...need to find out how to program each number pad for heating usuage
SHARP is not a hard one to get info for . try this web sight as they supply manual 's and also try googling sharp with your model # / and order one on line .. **** feed back pls ..
Dec 23, 2009 | Sharp R-23GT Microwave Oven
I heard a pretty loud pop on my Sharp R-1505 yesterday and the microwave stopped heating. Any ideas?
Oct 08, 2009 | Sharp R-1505 Microwave Oven
Sharp microwave stopped working
Is it totally dead? No display? Or just does not cook? If it made an unusual noise before it 'died' something probably shorted out.... You need an ohm meter to troubleshoot. If the fuse is open, switches and HV circuit need to be checked before replacing fuse. Sometimes on the convection Microwaves (not just Sharp) the fuse will 'rust' and open rather than blow. Or the fuse holder can over heat and fail.
Sep 11, 2009 | Sharp Microwave Ovens
I hqave a Sharp convection/microwave I bought in 1980. I love it but the microwave has stopped working anyone have any ideas as what to do. Thanks, Vicki
it could be the magnatron or the high voltage fuse, they are the common problems of a microwave not heating. ALWAYS GET A QUALIFIED TECHNICIAN OR SOMEONE WHO KNOWS HOW TO DISCHARGE A HIGHVOLTAGE CAPACITOR BEFORE ANYTHING INSIDE A MICROWAVE IS TOUCHED, ALWAYS UNPLUG FROM WALL ALSO!!!!
Nov 26, 2008 | Sharp R-1850A Convection/Microwave Oven
Dimentions
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
They should be able to tell you what current model is comparable to yours.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
251 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
