Question about Dell OptiPlex GX270 PC Desktop
PASSWORD PROBLEMS WHEN MY COMPUTER BOOTS UP IT GOES STRAIGHT TO THE MOS DOS ASKING FOR PASSWORD. I CALLED DELL THEY SAID TO GO INTO MY BIOS AND CHANGE PASSWORD. HOW DO I DO THAT?
  • 2 more comments
  • nightqueen Aug 27, 2007
    CAN'T FIND THE 3-PIN OR RESET JUMPERS
    THANKS FOR HELPING ME,BUT I STILL CAN'T FIND IT.DO YOU KNOW WHERE I CAN GO THAT WILL HAVE A PICTURE OF THE MOTHERBOARD?MAYBE I WILL BE ABLE TO LOCATE THE JUMPERS.
  • nightqueen Sep 01, 2007
    Was able to locate jumpers ,thank you.Now I have put a new hardrive in and I need a cdrom driver to install OS.Went to the dell website but was unable to get driver download.Is there a website that I can get the cdrom driver for free?
  • nightqueen Sep 02, 2007
    MY COMPUTER IS NOT RECONIZING THE CDROM.IT SAYS NO CDROM INSTALLED.THE HARDDRIVE I'M USING IS A HARDDRIVE THAT HAS BEEN SWIPED.THERE IS NOTHING ON IT .I REALLY NEED A CDROM DRIVER FOR A OPTIPLEX GX270.
    Brigadier General:
  • 6,966 Answers
Hi, To access or enter motherboard BIOS settings, on powerup either F2 or Del. If you just want to remove the password in your Dell Optiplex > The BIOS password may be cleared by removing the password jumper (PSWD) on the motherboard. This will also clear all CMOS settings: Open your casing, on your motherboard. find the CMOS password reset jumper (3-pin) on the motherboard; Remove the jumper from pins 1 and 2 and put it on pins 2 and 3 for about 5 seconds. Replace back the jumper on pins 1 and 2. Hope this be of help/idea. Good luck and kind regards.
Posted on Aug 27, 2007
  • 2 more comments
  • Louie  Role
    Louie Role Aug 27, 2007
    Hi again,
    For a Dell OptiPlex GX270 PC Desktop, the Paswword Jumper is located near the power connector.
    On not so recent versions of Dell, they use 3-pin terminals, however most newer models/versions use 2 2-pin terminals.
    Below is a copy of the jumper settings from the User manual available athttp://support.dell.com/support/edocs/sy...
    Cheers.
  • Louie  Role
    Louie Role Aug 29, 2007
    The previous post answered you "..I STILL CAN'T FIND IT.DO YOU KNOW WHERE I CAN GO THAT WILL HAVE A PICTURE OF THE MOTHERBOARD?..."
  • Louie  Role
    Louie Role Sep 02, 2007
    If you're planning on installing Windows, no drivers needed for the CD ROM.
  • Louie  Role
    If you are connecting your HD and CD ROM in tandem in a single IDE flat cable, you have to set your HD to master and your CD ROM to Slave. Normally there are instructions on the label of the HD on what pins should a jumper be placed to enable it as master. Likewise at the rear at the CD ROM there would be 3 pairs of pins, the middle is usually jumpered to enable it as slave.
    On first power on, go to your BIOS/CMOS and check if the motherboard has auto detected your HD & CD ROM.
    Problem Solver:
  • 5 Answers
Remove the battery on motherboard and boot ur system will not ask about password
Posted on Nov 07, 2007
Yo can clean the password by removing the battery for 30- sec. this will clean the Bios/Cmos
Posted on Sep 24, 2007
SOURCE:
I have a Dell Laptop 17RSE 7720 that I cannot Flash the Bios on. I have not tried to do it using Dos. I get Error 216 or 105.
nice a full model stated, rare here. NO OS< windows 10?
Windows, 10 ,removed the DOS mimic DLL files so now we must use freedos if DOS is needed, so I ask OS used above.
No reasons stated, the Intel processor venerability issue? what ?
or hacking BIOS , the possibles are ENDLESS. DYK
did you use F12 sandbox install
or did you make USB with freedos on it.
why not go to dell first and not fixya we are not dell.
ok?
do not flash BIOS until you learn the risks, did you?>
do not do that, unless you:
1: must, (have real compelling reasons to brick a good working perfect pc, (repeat 3 times for effect). oops....a daisy.
2; make 100 % sure the flash binary you get matches the exact service tag model PC you own , i bet you did not ask Dell to tell you that exact file that matches what you own.
I think but am not sure(dell has decompression locks on the file)
but I think they have more one ROM binary inside thee 10MB file.
but be nice if they said that, (their lil secret)
DID you used F12 mode? to update?
and from what version to what version.?????
3: Dell does not have what I call EZ_flash, that is using BIOS to flash itself. (super safe way, if power is good) Dell runs scripts at next boot to load bios binaries, in sand box , F12 way.
the EXE file there:
I always look first, I trust no one, on any binaries.
the exe passes virustotal and malwarebytes.
But the exe is locked, out. (decompression)
I think I know why (UEFI rules again)
5: is your PC set up with UEFI BIOS?
and safe boot? off
bitlocker suspended?
why not talk here at dell on same topic.
why leave DELL>?
https://www.dell.com/community/Laptops-General/Inspiron-7720-Bios-Flash-from-A14-to-A17-error/m-p/4663974
One more problem. UEFI is H3LL
most makers OEM now block regression paths of bios.
so are you regessing ? trying to load, older BIOS version
you cant in most cases. did you? no before after stated. versions.
also learn that many PC, they upgraded UEFI like 10 times
and some you must do step by step, never v1 to v10 ok?
or it fails.
now some faCTS ON LAPTOPS.
Dell does not use Ez-flash, sadly is the best there is, not used.
this method has no possible way to multitask and fail.
the second most safe is running DOS(freedos is free) HP does.
The third most safe way is windows sand box. way. F12 per dell
and 4th flashing under windows live, is totally wrong.
never flash on any preemptive multitasking OS, live. do not.
may tired, many died (bricked forever)
this version>?
Version Version 1.11.1, 1.11.1 Category BIOS Release date 03 Jul 2018 Last Updated 03 Jul 2018 https://www.dell.com/support/article/us/en/19/sln129956/dell-bios-updates?lang=en
The normal Dell way under w10 , it creates install scripts in a file on your
hdd (not bitlocker'd) and then reboots w10 to sand box.
then w10 runs in special mode,(no it is not DOS) and this mode
safely installed the flash binaries.
if this fails or the HDD is missing (lol) or has linux loaded, you didnt say, then you can do this.
The below from Dell uses the word DOS in lazy way.
its not DOS, ok> DOS is MS product, or DRI, DR.DOS
Freedos is a modern version of DOS that runs on new hardware the real DOS (MS) can never do. ok?
I am told dell uses the w10 sand box method (w7/8/10)
I see dell ended this switch, -writeromfile
you can not extract the rom file.
this makes FREEDOS disk boot on the USB.
did you do this?
=-------------------------------------off dell ------------------------------
QUOTE: "
BIOS Update Executable for Windows/DOS
Download
1. Click Download File to download the file.
2. When the File Download window appears, click Save to save the file to your hard drive.
Run the BIOS update utility from Windows environment
1. Browse to the location where you downloaded the file and double-click the new file.
2. Windows System will auto restart and update BIOS while system startup screen.
3. After BIOS update finished, system will auto reboot to take effect.
Run the BIOS update utility from DOS environment if Legacy Boot Mode(Non-Windows users)
1. Copy the downloaded file to a bootable DOS USB key.
2. Power on the system, then Press F12 key and Select "USB Storage Device" and Boot to DOS prompt.
3. Run the file by typing copied file name where the executable is located.
4. DOS System will auto restart and update BIOS while system startup screen.
5. After BIOS update finished, system will auto reboot to take effect.
Run the BIOS update utility from DOS environment if UEFI boot mode with Load Legacy Option disabled (Non-Windows users)
2. Power on the system, then go to BIOS Setup by pressing F2 and go to "General-Boot Sequence - Boot List Option".
3. Change "UEFI" to "Legacy" of Boot List Option.
4. Click "Apply","Exit" to save changes and reboot system.
5. Press F12, then Select "USB Storage Device" and Boot to DOS prompt.
6. Run the file by typing copied file name where the executable is located.
7. DOS system will auto restart and update BIOS while system startup screen.
8. After BIOS update finished, system will auto reboot.
9. Go to BIOS Setup by pressing F2 and go to "General > Boot Sequence > Boot List Option".
10. Change "Legacy" to "UEFI" Boot Option.
11. Go to "Exit > Exit Save Changes" and reboot system.
Note 1: You will need to provide a bootable DOS USB key. This executable file does not create the DOS system files.
Note 2: Please make sure you suspend BitLocker encryption before updating BIOS on a BitLocker enabled system.
If you don't enable BitLocker on your system you can ignore i
Jul 31, 2018 | Dell Computers & Internet
My dell d610 is asking for a hdd password. what would it be there is no password for this computer?
HDD password? Is the laptop encrypted? Unless it s a system password set in the BIOS. You'll have to know what that is or reset it.
Reseting the BIOS requires taking apart the laptop and finding the CMOS battery and shorting it.
Oct 22, 2012 | Dell Latitude D610 Laptop Computer -...
Hi, I have NEC Versa E6300 laptop. I had set its BIOS password long back but forgot now. I want it to boot from CD and need to change the option in BIOS. Can you please suggest, how can I reset this...
Hi Prajeet
To reset your BIOS password you need to call the NEC to give you a reset code. Most Computer manufacturers like DELL, HP do have password reset tool from their end. you just need to call them to ask for a reset code but expect to answer all security questions before they gave you the reset code.
Thanks for using Fixya.
Apr 09, 2011 | NEC Versa SXi Notebook
Dell inspiron 630m bios password problem
usually the bios password is 0000 by default
Mar 13, 2010 | Dell Computers & Internet
Dell Laptop BIOS password recover
Hello
Thank you for using
FixYa for your problem
A reliable method can be found here:
http://www.cgsecurity.org/
look for Password recovery.
Try the backdoor password Dell
: all bios passwords can be removed easily,
: 1-create a dos system disk,
: 2- copy "debug" (this is a dos command found in windows\command directory) onto the system disk you created,
: 3- boot the machine with this disk,
: 4- at dos prompt type: debug then enter, you will see a blinking dash
: 5- type: o 70 2e then enter, (also seen: o 70 18)
: 6- type: o 71 ff then enter,
: 7- type: q then enter,
: 8- remove the floppy and reboot! Power the system off and on by unplugging and re-plugging the system into the power outlet
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Dell Computers & Internet
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
I have problem with the lock paswerd
If you have a BIOS level Password (Before Windows) contact Dell Tech support (800-624-9896 USA) confirm ownership and they can assist in clearing the password.
If it is a Windows Password, you will most likely have to either remember the password, boot to admin account in Safe mode (If XP Home) and change the password there, or reinstall windows
Aug 07, 2009 | Dell XPS M1210 Notebook
Bios password
Bios password can only be reset by removing the c-mos battery....A c-mos battery is a small battery in motherboard, remove it and then replace it again..dat will reset ur bios password..
Jul 05, 2009 | Dell Latitude ATG D630 Laptop
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
Bios default password
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
Mar 04, 2009 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
1,352 people viewed this question
Ekse
Clive
Clive
