Question about Refrigerators
Model fgus2642lf makes ice but flap door opens and closes right away
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
the dr
  • 447 Answers
SOURCE: Ice Dispenser - in door
Yes that repair is quite common and not too difficult you need a Maytag Fountain door Kit dont have the part# hear but can be researched available at all appliance part retailers........comes with the solonoid, new flapper door and outher redesigned pieces also an instrunction sheet A solved rating is great motivation to continue giving priceless advise........
Posted on Oct 03, 2007
fridgetech
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at http://www.appliancepartspros.com/.
Posted on Oct 21, 2007
catriver
  • 878 Answers
SOURCE: THE ICE DOOR PROBLEM
Budd, if you want to stop the flapping until service shows up to replace the high voltage board do the following: remove the drip tray, remove the 2 screws under the drip tray. From the bottom, where you removed the screws, pull out and up. The whole disp cover lifts off. Unplug the 2 harness going to the board on the dispenser. The refrigerator will still operate normally minus the dispenser. Catriver.
Posted on Dec 25, 2007
aborcass
  • 2651 Answers
SOURCE: Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Posted on Nov 20, 2008
The place where the ice is held when I go to crush the ice it falls out the bottom of the freezer do I need a new ice container
sounds like that may be we had so many problems with ours that I tore it out and threw it away .
Mar 03, 2015 | Refrigerators
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Ice will not dispence thru door.
Without knowing the brand and model # I can offer the most common solution.
On most "pass the ice through the door" models there is a flapper door where the ice dispenses. The spring which holds this door closed when you are not dispensing ice becomes weak allowing the flap to stay open jsut a bit. This open space will create an ice dam in teh dispenser thus not allowing the ice to dispense. The repair is generally made by replacing the flap assembly.
All the best.
Nov 21, 2010 | Refrigerators
The flap for the ice dispencer on the freezer side of the door will not stay closed. There seems to be a part missing from the flap. Maybe a spring or something. Can I get this fixed myself for less than...
you need to send the model number so i can look up your machine to see the part numbers,there's a piston that is used to close the dispencer door,close it and don't use it,if alot of hot air gets sucked inside there it could cause big problems depending on how wide open it is.the model number is on the right side wall up near the ceiling in the fridge side or if it's older it could be down near the bottom hindge on the fridge door.send the model number,i don't know if that part is less than 50 bucks
Aug 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bottom of ice dispencer freezes and wont let ice come out. It is a whirlpool side by side
Check the door flap on the freezer door , which opens to let the ice come thru . If this flap does not close completely , then it will let frost accumulate inside the ice bin , blocking ice from dispensing . If you had given the model number , I would give the part number for the door kit .
Aug 15, 2010 | Refrigerators
Whirlpool side by side with ice maker dispenser not working
Hello, we are sorry to hear that you are experiencing this problem. We would suggest checking the ice chute to make sure that there is no ice lodged in the way of the flap. If the issue persist we would suggest having a certified technician out to look at the Refrigerator. If you would like further assistance you can send your name, phone number, address, model/serial of the appliance and the date on which you purchased the Refrigerator to Whirlpool_Reviews@Whirlpool.com. Thank you.
Apr 17, 2017 | Whirlpool Refrigerators
Ice maker freezes up
Check to see if your ice door flap is closing each time after you remove your glass of ice. If it is staying open or not closing all the way, then this is your problem. You will need to dismantle the water and ice through the door assembly to see what your problem is. This is pretty involved on most refers and there are too many ways these are built to tell you how without a model number. Be advised that ice build up in the crusher can happen with normal usage and no mechanical problems. If this is just an intermittent problem it is probably caused by a piece of ice jamming your ice door flap open long enough for hot moist air to get into your ice bin and cause it to refreeze as a solid ice mass. When you are done getting ice, reach up inside your door and make sure no ice is stuck in the door. A pain to do, but the alternative is to dump all your ice and clean out your crucher every 1 to 6 months when it occurs. Good Luck Appliance Specialists
Dec 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice dispenser door flap will not close completely. I'm sure something has sprung or broke inside the door. How do I get the face off to look at the mechanism that opens and closes the door?
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
