Question about Orbit Irrigation 57009 WaterMaster Pump Start Relay
Using model 57009 my pump wont shut off after timer cycles
2 Suggested Answers
SOURCE: have a orbit 57009 pump start relay but pump does not turn off
It sounds like a stuck pump relay.
Posted on May 06, 2009
Bosch Dishwasher model #SHU3002UC-06 continues to run on any cycle, does not stop at the timer shut off spot
Anti flood device in a lot of german machines and pump keeps running only way to knock it off is too un plug what has happened water has leaked possibly over a period of time ,and set the anti flood device off if ya disconnect macine plug and drain hose and lie on its side water will drain off anti flood put some towels to catch water and macihne should work after ya reconnect
Nov 01, 2015 | Bosch Dishwashers
My roper dryer works fine, it heats and the timer advances, it just wont shut off at the the end of a timed dry or auto dry. What do you think?
A timed drying cycle uses the timer alone to stop the drying cycle. Once it times out like an egg timer a set of contacts open up shutting off the dryer. Or a set of contacts closes to activate a relay which in turn shuts off the power.
Auto dry usually uses a moisture sensor which would do the same thing as the timer. Once it doesnt sense moisture in the load for a predetermined time it in turn triggers a relay which shuts the power off. Some auto dry cycles just use the timer alone and guess-timate the drying time by the selection.
If yours does not use a moisture sensor then most likely it is your timer/cycle switch. There may or may not be a relay involved.
Most dryers have a basic wiring diagram on the inside somewhere on one of the panels which will help.
Since yours is acting up on both cycles Im guessing you have a bad relay or connection to that relay somewhere IF it uses a moisture sensor.
Dec 17, 2014 | Roper Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
GE washer wont drain or spin, lid switch has been replaced and so has the timer. At the start of cycle it fills and aggitates properly.
If the machine tries to spin for a few seconds and shuts down because the tub is full of water, then - The first thing I would do is check the pump. You may have something blocking the pump or the pump could have failed. Newer models built within the last 10 - 15 years must drain their water down first before they are able to spin.
Jul 28, 2010 | GE Washing Machines
Dryer wont stop Timer wont work either Cycle
058aeba.jpgReplace the heating element if it is bad. if it is not then replace the high limits mounted on it at top and bottom
Sep 27, 2008 | Roper RES7646KQ Electric Dryer
Kenmore model # 110.20722990
ck all motor connections just lean washer back against wall motor is right at front if motor ckd ok 2 things left motor or timer neither one is cheap but best guess would be timer
Sep 08, 2008 | Kenmore 24032\24036 Top Load Washer
Wont pump water
If it did not pump at all I would say you had a bad pump. Try removing hoses and check for plug up. If there is no plug up, I would manually try to adjust the timer to see where in the cycle it does not pump. It could be a bad cycle timer.
Feb 04, 2008 | Hotpoint WMA30 Front Load Washer
Orbit Irrigation 57009 WaterMaster Pump Start Relay Logo
Top Orbit Garden Experts
squeely
richie46
Are you an Orbit Garden Expert? Answer questions, earn points and help others
