Related Tags:
This problem should be removed because:
Problem with Kenwood KDC-MP4028 CD Player
Forgot my code.
I connected the stereo in my car about a year ago and I put a code on it, now that I want to change the stereo into my pick up, it is asking for the code and I cant remeber it. I tried many but I can't seem to get the right one.Would any one know if I could reset the code and how?
Solutions (13)
Best Solution
How do I Reset a Kenwood Security Code?
Kenwood car stereos are protected against theft by four digit security codes. If a thief steals a Kenwood car stereo, they will not be able to use the stereo until they enter the secret for digit security code.
Unfortunately, many legitimate owners are also locked out of their Kenwood car stereos due to these security codes. This typically happens to people who buy used cars from people who forget to share the security code. However, it also happens to people who simply forget their security codes after several years.
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Finding the Kenwood Security Code
There are backdoor codes for each Kenwood car stereo, based upon the model and the serial numbers.
These backdoor codes are closely held secrets. Outfits like Car Audio Accessories UK will sell you the code for your radio for £20.
Sending Your RadioBack to Kenwood
If all else fails, you can send your stereo back to Kenwood to have the security code reset
HOPE THIS HELPS!!!!! -- AMPMAN--
What button should I push if I don't have an "auto" button, both on the remote or the head unit? I have a dNx-5140. All help would be appreciated.
Press and hold the Auto button.
While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec.
Enter KCAR using the <"Arial, sans-serif">remote control from a higher end CD Receiver or any Excelon CD Receiver.
“K”: Press TRACK UP key (>>|) after pressing 5 key twice.
“C”: Press TRACK UP key (>>|) after pressing 2 key once.
“A”: Press TRACK UP key (>>|) after pressing 2 key three times.
“R”: Press TRACK UP key (>>|) after pressing 7 key twice.
* If you commit a mistake in the code entry, the unit enters the
code request mode again.
Press the Track Advance button on the remote to enter the override code.
The unit will enter the All Off or Standby mode if done properly.
Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD.
Press 55222277 on the remote. There will be NO visual verification when entering the override code.
Press and hold the Volume Up button.
While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec.
I changed my battery in my 2008 honda now my radio is asking for me to enter code.. help...plus my button kill switch will no longer work help
I need the code to unlock my KDC322. Will deeply appreciate any help. sconley60@hotmail.com
i need security code kenwood DPX8200WMP
i need the code for a KDC-MP7028
i need the code for a KDC-MPV 619
- please i want to know my code to help me in hi5..can you help me please???
i have kdc mp4028 ,where is aux option ?
code Kenwood DPX-MP5070
needed security code for KDC-MP6029/5029
I need help with a KFC-4019 code reset or back up code
Suggested Solution (3)
try this
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Source: Forgot my code.
Type 1
Type 2
Type 3
Source: Can't remember my code.
I connected the stereo in my car about a year ago and I put a code on it, now that I want to change the stereo into my pick up, it is asking...
Forgot my code.
Forgot my code.
Forgot my code.
Forgot my code.
Add Your Solution
RADIO CODE 2003 HONDA PILOT
WHERE CAN I FIND THE RADIO CODE FOR HONDA PILOT 2003
Fix-O-Meter
17,344
17,344 people viewed this problem
- 43 people found this problem to be helpful.
- 3 people are following this problem
Top Kenwood In Dash Receiver Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
i dont have a remote for my 4032..i bought my 92 ford with a kenwood in it... but cant access it. is there another way without the remote?
