Canon calculator; p28-d Where can I download a manual. The ink pad or ribbon may need to be replaced. It calculates but does not print Thanks Jerr
marsrover
  • 682 Answers
SOURCE: replace ribbon
http://www.sharpusa.com/files/cal_man_el2630P.pdf.
Posted on Mar 09, 2008
  • 3 Answers
SOURCE: Canon Calculator
Okay just figured this one out but on the back of the claculator there is a slip slid paper in that Press the feed key and allow the paper to feed through the claculator if it doesn't feed through push the paper in a little and hit the feed key again. It worked for me
Posted on Oct 04, 2008
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
SOURCE: Changing Ink in the Canon P170-DH Printing Desk Top Calculator?
The manual for the Canon P170-DH calculator is found on the canon usa web site. It is 22 mg in size, but prints out to 4 pages in English, Spanish and French.
According to the manual: Use only Ink Roller CP-13.
There are four figures showing the steps, so you'll have to imagine it.
1. Turn power switch off.
2. Remove the printer cover (Figure1).
3. Hold the tab of the ink roller. Lift the ink roller out of the base (Figure2).
4. Insert the new ink roller into position. Push down on the center of the ink roller until it locks into place (Figure3).
5. Replace the printer cover (Figure4).
Print out the manual for yourself and put it in a safe place.
Posted on Nov 24, 2009
  • 16 Answers
SOURCE: need to replace ribbon on canon mp25dv calculator
remove the printer cover, insert one spool on the left side pin, guide the ribbon though printer and inset other spool on right pin. make sure the ribbon looks like a C with the ribbon coming around the outside of each spool.
Posted on Apr 28, 2010
How do you change ink ribbon/cartridge?
It's the ink roller you need to replace - it's on page 3 of the user manual (attached link to it). Canon P23 DHV User Manual Page 3
Jul 12, 2016 | Canon P23-dh V 2 Color Mini-desktop...
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
How do I change the ink cartridge?
go to your browser search box type Instruction manual for Canon P27 -DH 12digit mini desk top printing calculator . on the page that appears you will see a PDF OF THE INSTRUCTION MANUAL. on the machine lift lid and the ink cartridge can be seen , you can lift the ink cartridge out and replace . Suggest download PDF just in chase .
Dec 24, 2015 | Canon P27-DH 12 Digit Mini Desktop...
How do I correct blurred calculator printing
Cleaning the print head and replacing the ribbon should take care of this for you
Nov 29, 2015 | Canon P170-DH Printing Calculator
Only prints in red
may have print ribbon installed upside down. what happens if you try printing a negative number? if that number prints in black, try turning ink ribbon over
Jan 02, 2014 | Canon MP49D Calculator
I have a p100 dh calculator and the printing is unreadable. what can I do?
Do you mean the printing is unreadable because it is faded?
Replace the ink ribbon.
Jul 15, 2009 | Canon P100-DHII Calculator
Nov 20, 2008 | Canon P170-DH Calculator
Canon Calculator; P28-D
Hi there, there are a couple possibilities. First, Remove the cover where the paper feeds out, if there is a ribbon or an ink roller in there it will need replacing. This you can get a staples. The other possibility is, if there is no ribbon or ink roll, it is probably a thermal printer which means is uses a special heat sensitive paper. If this started when you changed the paper, this is most likely the problem. This you can also get at staples!
Jun 19, 2007 | Canon BP120 DH Calculator
53 people viewed this question
k24674
jasbo
jasbo
