Question about Kitchen Appliances - Others
Cme256 scotsman continually dumping water (it won't shut off automatically)
    Novelist:
    Champion:
  • 373 Answers
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Posted on Jul 07, 2014
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Posted on Mar 01, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
SOURCE: My Scotsman machine cme256 take
Problem too long ice production CHECK THE FOLLOWING: check the refrigerant charge check the hot gas solinoid valve compression test the compressor check the ambient and water temp. check the condenser fan motor and condenser coil check the txv and sensing bulb if in proper location
Posted on Jan 10, 2011
What can I do to fix cem256 ice machine that the refigeration light blinks twice ?
http://hvac-talk.com/vbb/showthread.php?679751-Scotsman-CME256-Water-Diagnostic-Light-Problem
May 15, 2014 | Scotsman Ice Machine - 290lb...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Cme256 scotsman
Remove and clean or replace the bin control sensors ( set of two ) part number 11-0540-21. Most of the time you can remove them and clean the little lights and this will do.
Jun 27, 2013 | Kitchen Appliances - Others
Does dump valve shut off after making ice
is your bin line and dump line tied together if so it could be just ice melting. If not can you here water filling up constantly while machine is off? if so is it running over sump tray into ice bin. if dump valve was stuck open then machine will not make ice.
Jun 25, 2013 | Scotsman Kitchen Appliances - Others
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My Scotsman machine cme256 take to much time in the cycle to make ice
Sep 13, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Cme256 scotsman ice machine
Apr 15, 2010 | Scotsman Cooled Modular Contour Cuber Air...
Kitchen Appliances - Others Logo
135 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
