Question about Waterway Above Ground Hi Flo Pump
Need to know where to hook up the 2 black wires for the 2peed switch on a 48 frame hi-flo 115 volt waterway pump and where the black/white wires go only have lines 2,3 and 4
KMusselmann
  • 247 Answers
SOURCE: got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Is there a coverplate where the wires come out of the pump? If so, remove the plate and there should be a wiring diagram inside.
Good Luck
Kurt
Posted on Mar 18, 2009
TheSpaDoctor
  • 10 Answers
SOURCE: electrical connection to pump
can you photograph the new connections for me? if you look at the connections, the neutral normally has a solid link across it, the earth will be to the frame and the other two are the high and low speed live connections.
info@the-spa-doctor.co.uk
Posted on Mar 25, 2009
  • 990 Answers
SOURCE: waterway hi-flo above ground pool pump just
If it's rattely clean the impeller, If it's screechie bad bearing probally caused by a bad seal and it will need a new motor and seal.
Posted on Aug 24, 2009
  • 990 Answers
SOURCE: waterway hi flo above ground pump
If not on top of the motor it could be in the back mounted to the end bell. Many motors now don't have a start cap but are wired to get this done. Sorry to say but a lot of motors are ment to be throw aways nowadays.
Posted on May 01, 2010
john224
  • 1378 Answers
SOURCE: 1.5 hp waterway pump hooking the wries to the motor
If it is an AOSmith motor white will be the top, high in the middle and low on the bottom. You'll need to determine if your black or red is high and the other will be low.
How do I change the Waterway 48 frame side discharge to the opposite side?
You should be able to remove the pump housing and rotate it 90 degrees or 180 degrees. Then replace bolts and see if your good to go? Thank you Joe have a pleasant day. Leave feedback.
Jul 14, 2016 | Waterway 1.5 HP 115 Volt 2 Speed Side...
Waterway pump four wires res white black green which is ground old pump1.5 hp had three connectors plus screw ground new pump has four connectors plus screw ground
make sure new one is wired for 120 volt then the black goes to the L1 the white to L2 then the green to ground or case make sure to change brown and white to accomidate 120 volts
May 17, 2014 | Waterway Executive 48 Spa Pump 2hp 1spd 2"...
Proper wire hook up
black goes to L1 white goes to L2 make sure to look on side of motor to change from 220 volt to 110 volt either a knob or changing wires brown and white to different locations hope you didnt fry motor
Jul 26, 2013 | AO Smith 1.5 hp 3450rpm 48Y Frame 115/230...
My new AO Smith motor does not have an L1 IT has L2, L3, and L4 so how do I hook the wires?
There is a schematic on the motor itself to show you exactly how to hook it up. The main thing is knowing whether it's 115 volt or 230 volt connection. Good luck any questions hit me back up.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
Apr 26, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
How do I set the Waterway Champion Pump for 115 Volts? I have the same problem, just installed and it runs for a bit then shuts off. It was mentioned that the pump is usually set for 230, so how do I set...
The voltage is not optional. What voltage are you plugging the pump into?
If you are plugging it into 115, the pump must be set for 115.
If you are plugging it into 230, the pump must be set for 230.
Usually there is a wiring diagram on the label on the pump body or if you remove the end cover, there may be instructions there. There may even be a switch or terminal that states 115 volts and another that states 230 volts.
Gary
Jun 29, 2011 | Waterway Champion 1 1/2 Hp 230v Energy...
Changing hot tub pump flo master power cord to new waterway pump diagram say common white line to port no 1 port no 1 hase an orange wire on it allready wire leads in to motor housing. not sure where white...
DO NOT PLAY AROUND WITH THE WIRING OF THIS 2 PEED.
you can cook the motor in just a few seconds != junk
yes WHITE is common RED is low and BLACK is high
A picture of the connections in the back of the motor is needed for further assistance
Jay the pool pump repair guy in longwood Florida.
Mar 02, 2018 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
May 01, 2010 | Waterway 1 HP 115 Volt 1 Speed Center...
Got a waterway 1.5 hp 1 speed 115/230v, wired 115 need 230
Good Luck
Kurt
Mar 18, 2009 | Waterway Champion 1 1/2 Hp 230v Energy...
Waterway Above Ground Hi Flo Pump Logo
43 people viewed this question
Top Waterway Garden Experts
Mike Raino
Level 1 Expert
john h
roeb
Are you a Waterway Garden Expert? Answer questions, earn points and help others
