Question about RCA G36788LV 36" TV
Wont power up
The set wont power up, just get several clicks. The x-former fly looks to have smoked, have a new one coming. I have also noticed that a dime size disk, appears to be solid with two legs soldered on, it says 100-o1a and 81775 or 91775 the legs have let loose, is it some sort of resistor or a thermal fuse? can I solder it back in ? Thanks Tim
  • 398 Answers
The G36788LV uses the CTC197 series chassis. When the set will not power up, the most common cause is a shorted flyback, so you are probably on the right track there. The small part you describe is the degaussing thermistor. It only works for the first half-second when the set is first turned on, and it sends power to the degaussing coil. If you are careful, you can solder the legs back on but be careful not to heat the thermistor too much because it will crack in half if overheated with a soldering iron.
Posted on Aug 27, 2007
Pontiac sunfire radiator
get a radiator flush and replace the hose
Jan 22, 2014 | Cars & Trucks
SMOKE COMING FROM DASH, LOUD POP. CAR WONT START. IT TURNS OVER BUT WONTS START 92 DIAMANTE
if its smoking thats a shorted system..if you feel safe with fixing it do so otherwise get rid of that deathtrap..
Dec 25, 2013 | 1992 Mitsubishi Diamante
My car wont start. There is power to the car but I hear a clicking noise when I try to crank it.
Fly wheel may have teeth that broke off pull the starter look for chew marks.
Nov 04, 2011 | 2001 Mercury Cougar
Bought a brand new Williams wall heater a month ago "converted" for propane. It worked great for aprox a month now it wont come on. The piliot is lit but just wont come on?
check thurmostat. check low voltage. check limit switch there may be several.limits should be closed. I usually push re set first, if there is a click,then switch was open.limits trip when they get too hot.is this ventless? is the vent o-k?
Dec 23, 2010 | Heating & Cooling
Bike lacks bottom end power and topend doesn't hit band properly and it bellows smoke but its like gear box oil smoke its not running rich it has a new set of piston and rings the carby is fine and at...
Who put the new crankcase seals in your bike? Sounds like your sucking oil out of your crankcase if it is blowing all that smoke.just fixed Cr125 doing same thing.
I’m happy to assist further over the phone at https://www.6ya.com/expert/michael_18b4936ebf017b21
Dec 20, 2010 | 2003 kawasaki KX 125
My samsung plasma tv went out and it just makes a clicking noise and wont turn on i replaced the power board but it still does the same thing help anyone!
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
Jan 01, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Flyback shorted, trying to replace
astimagnetic.com:flybacks.video heads,laser pickup and more...
Jul 08, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
2006 susuki swift wont start
Maybe the security system was not set to valet when service was done. If the alarm was triggered for several times, the security padlock will engage.
Jul 06, 2009 | 1997 Suzuki Swift
Skoda Octavia Elegance 1.9Td
sounds very like twin mass fly wheel fault you will need to replace clutch along with fly wheel
Feb 11, 2009 | 2001 Volkswagen Golf
Hitachi 50ux58b 50"
hello. it sound like a power supply problem to me .!!! it could be a bad solder joint.!!! or a bad fly back transformer.? "good luck"
Jul 27, 2008 | Hitachi 50UX58B 50" Rear Projection...
Televison & Video Logo
111 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
