Question about Ovens
Jenn-Air SEG196 Oven Control Board
The display on my Jenn-Air Model SEG196 (Oven Control Board 12200028) no longer displays anything. I know I can send the board to various repair services online who charge $160+ if they can repair it. Are there any less expensive solutions?
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
SOURCE: Problems with Jenn-Air Electric Double-Wall Oven
Try changing the clock assembly --
http://www.partselect.com/ModelFrames.aspx?ModelID=221346&ModelNum=WW30430P&mfgModelNum=&ManufactureID=1&Selected=51238&Position=1&mfg=Maytag&Type=&Mark=1
here is a link to the diagram.
PS120923
Electronic Clock Assembly (Series 10)
Help with series numbers
here is the part number.
Posted on Feb 17, 2008
SOURCE: dim light on oven display w30400b jennair
The circuit board is for the display/touch panel. It is mounted on the back of the display panel itself and connected to the other circuit boards by two multipin connectors. When you remove the display panel (3 screws on top, 4 on the bottom) you will be able to GENTLY detach those connectors. They are low voltage and may be handled safety even when the oven is powered, but I agree that turning off the oven circuit breaker is good practice.
To remove the circuit board, GENTLY release the two black plastic tabs; the solder pads are underneath. I too used a 100 mf capacitor because no local supplier had a 68 mf hi-temp. Observe polarity; the (-) lead goes towards the center of the board (away from the edge connector.)
BTW, I had exactly the same symptoms (display goes dim, then goes out altogether.)
Posted on Jan 22, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
douglas9101,
I had the same problem and found the solution on-line.
Replace the C3 capacitor on the dispaly module. (100 UF, 35 volt, high temperature)
The local Jenn Air dealer wanted $211 for a new display module.
I purchased a Cap from a local electronics supply store for 79cents.
The only problem is that you need to have a soldering pencil/iron, a solder ******/wick and a small amount of solder.
Steps I had to take on my oven:
- Flip the AC breaker supplying the oven to off to be save
- remove 3 screws on top and 4 on the bottom of the display panel
- gently pull out the display panel and unplug the 2 cables to the display
- unclip the ribbon cable to the display module
- unclip the module itself by pushing on the 2 black tabs
- locate C3
- unsolder C3 and replace with new Cap- keeping the polarity strip the same as theh old Cap
- reasemble in reverse order.
It took me all of 20 minutes. It may sound difficult but is very easy if you have the tools
Good Luck
K
Posted on Jun 15, 2009
  • 3 Answers
SOURCE: Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
Posted on Jul 10, 2009
My Jenn Air oven digital display went out, what I
Apr 10, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
douglas9101,
- locate C3
Good Luck
K
May 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Ignitor not working
Check the ignitor, Make sure that the connection are good and tight. If they are then look at your control board which is located behind your clock. Then check your relay also.
Feb 20, 2009 | Jenn-Air JGW8130A Electric Single Oven
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
The light and temperature display are very dim and hard to see.
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 23, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
Steve Patterson
303-256-8494
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Jenn-Air Gas Range SEG196 NO CLOCK/DISPLAY
THE ONLY SOLUTION FOR THE BAD DISPLAY IS TO REPLACE THE CLOCK. I HAVE A JENN AIR OVEN TODAY AS A WORK ORDER TO REPLACE THE CLOCK FOR A FAILED DISPLAY.
FOR THE JGW8130DDB WITH NO POWER ANYWHERE, IT SOUNDS LIKE YOU HAVE A SUPPLY PROBLEM. MAKE SURE THE WIRING IS HOOKED UP WITH THE RED AND WHITE WIRES RECEIVING 240 VOLTS AND THE WHITE WIRE ATTACHED TO NEUTRAL / GROUND.IF THE OVEN HAS A BARE COPPER WIRE AND THE HOUSEHOLD WIRING ONLY HAS THREE WIRES, COMBINE THE WHITE WIRE AND THE COPPER WIRE TOGETHER AND ATTACH TO THE HOUSEHOLD NEUTRAL / GROUND .
UNLESS YOU ARE SURE ABOUT THE HOOKUP IN THE BREAKER/FUSE BOX, DO NOT GO SIMPLY BY THE COLOR OF THE WIRES.
Apr 10, 2008 | Jenn-Air JGW8130A Electric Single Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Ovens Logo
55 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
