Where do I put the washing powder in the Rossby 5 Samsung top loader machine?
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
Washing machine won't wash when on large cycle
without stating the make and model it makes it harder for us to help you figure them out .front loaders are more prone to this type problem than top loaders .could be the gear box is going bad or a belt getting stretched
Oct 06, 2015 | Washing Machines
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a 13 kg Samsung wobble technology top loader and have a problem with washing powder not dissolving. and no! I do not use too much powder per load, in fact am using less and less and my problem
Be aware that most washing powders have filler in them, mostly sodium sulphate. Only the really expensive brands do not. This will not dissolve as readily. Try using liquid wash detergent instead.
It is not a good idea to post your personal email on this public forum.
Feb 10, 2014 | Washing Machines
I bought the Samsung 8 kg Top Loader (Model: WA80V3WIP) a few weeks ago. I only use cold water and bought the yellow packet of Sunlight washing powder, which specifically says on the packet that it works...
As with any top-loader, the soap drawer will deposit the entire soap load on one spot within the first few seconds of water fill. When the water starts running through the soap drawer, the brakes on the drum are released, so you can manually rotate the drum to disperse the soap over the load surface, thus eliminating the concentrated spots. Also, you may save the duvet, as the white marks are most probably dried soap powder which can be removed with a damp cloth wiped over the area.
Oct 19, 2010 | Samsung SW62ASP Top Load Washer
I rented a home and ive got a washing mashine(simpson esprit 450),so my poblem is how to use it.i have to put washing powder first? and where to put?then what?....pls help
Hi just read your posting.Is your machine the TOP LOADER model or the FRONT LOADER model.Please reply with additional information and I can help you with instructions on how to use the machine.
Aug 01, 2010 | Washing Machines
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Ultimate Care II top loader washing - rinse issues
New concentrated powdered detergent takes very warm water to break it down. As for most dark clothes use cold water. I have one of these top loaders and for my cold wash colored clothes I use a liquid detergent and have no problem.
May 06, 2010 | Whirlpool LSQ8000 Top Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Leaking Water
try pouring boiling water down soap draw possible blockage due to cheap wash powder take off lid and massage down pipe then put on wash with no clothing
Nov 10, 2008 | Samsung WF337AA Front Load Washer
Samsung, rossby washing machine
There is a capacitor linked to your motor by wiring.. That capacitor is most likely the fault... It is normally a 400vac 12UF(J) capacitor
Jul 10, 2008 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
