Question about Hotpoint Dryers
Hotpoint Aqualtis AQCF 952 BIUK instructions
I have been gifted a Hotpoint Aqualtis Tumble dryer AQCF952 BIUK and can't find an instruction manual anywhere!!!
TAGTEL
  • 16 Answers
SOURCE: TUMBLE DRYER DOES NOT GET HOT
Hi, - The first thing to do is UNPLUG THE DRYER! Then remove the heater cover situated on the back panel. It is the curvey shaped panel.
Remove all the screws and the panel may be slightly stuck - just prise it off.
Next - there are 2 small screws holding the heater and thermostats assy onto the back panel. - Remove these to free the assy from the back panel. Be careful not to touch the elements as they break easily.
The problem is probably the Thermostats.
The one on the left is the Overheat Thermostat - You will notice a small hole in the centre of the thermostat. Take a Pin and push it firmly into the hole and you may hear the Stat "click". That has re-set the stat.
Re-assemble the Dryer being careful with the elements.
Now - Why has it tripped? If it has overheated it is because of one or all of the following.
1. The Condenser unit is getting blocked - Remove and clean under running water like a hosepipe or tap.
2. The door filter is not being cleaned
3. Sometimes opening the door to check if the clothes are dry and then not allowing the dryer to cool down can cause the problem. Always allow it to go through the cool down process.
Hope this helps. The Heater and the Thermostats are available as Spares - Terry
Posted on Mar 15, 2008
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
SOURCE: free manual
Hi Mark,
Try putting this into the address bar of your browser
http://laundry.manualsonline.com/manuals/mfg/hotpoint/aquarius_aquarius.html?s=fpw
Posted on Mar 22, 2009
  • 22 Answers
SOURCE: hotpoint tumble dryer making a banging noise, is
This could be a simple fix or more of a major task, so if you think you can have a go then great, first find tools and torch, empty any clothes, unplug from the power supply,disconnect vent if any, place unit on a table or bench then remove the back check for large quantities of fluff and dust, clean as much as possible, see if drive belt is secure and not damaged if this is not the case then the drum bearings may be worn, try to move the drum up and down, try the same thing from inside the door, as these dryers tend to wear front bearings quicker than rear ones, if excessive wear and you are confident, remove the drive belt and tensioner take note of the layout, remove supporting bracket at rear of drum taking careful note of where any nuts bolts are from, withdraw the drum you should now have access to all the bearings which are usually like a special plastic runners or ring, contact local supplier stating make and model number ask for a bearing kit, replace bearings and rebuild machine, all this could take up a few hours to a few days so ensure you can manage without a working dryer.............good luck
Posted on Nov 19, 2009
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
F04 fault on a hotpoint aqualtis tumble dryer. Also 4 lights flashing. HELP!
This should be in your manual?
F04 Rear thermostat fault Advice: We recommend you call our customer service centre to book an engineer on: 0344 822 4224
Aug 19, 2015 | Hotpoint Washing Machines
I am looking for a manual for hotpoint aqualtis AQCF 852 BU. Can you help please?
I have the same dryer and went on the Internet and typed "Hotpoint Aqualtis" on Google. One of the alternatives is "Instruction Booklet" This when printed is the Manual for the dryer, in full.
Aug 25, 2011 | Hotpoint Dryers
I am looking for an operation manual for a Hotpoint Tumble dryer. Model TDL31S
Try the following site.
WWW.HOTPOINTSERVICE.CO.UK
In the menu on the left, click on USER MANUALS, enter your model in the search box.
Then download the instructions.
Nov 19, 2010 | Washing Machines
Tumble dryer drum won't turn hotpoint vtd00
You are referring to the rear drum bearing that has worn away..
It means replacing the rear bearing and drum shaft.
It comes in a repair kit which you can obtain from Hotpoint.
It comes complete with fitting instructions.
Go the Hotpoint web site, and you should be able to order the parts on line.
In the menu click on>>>>Spare parts and accessories, and follow instructions.
Please ratemy solution.
Thankyou.
Jan 31, 2010 | Hotpoint Dryers
Hotpoint Aqualtis Stacking Kit
I Have the same machines and the only option is the Hotpoint stacking kit. Available from Hotpoint - 08448225225. They are selling it half price at the moment for around £70 delivered. I have been assured by Hotpoint this is the only option.
Mar 01, 2009 | Silver King Stacking Kit For SKR27 and...
Hotpoint tumble dryer tdl31p
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Jan 23, 2009 | Dryers
Tumble dryer
Go to:
www.hotpoint .co.uk
Click on After sales, then on download user instruction books, put in you model number, and down load to your computer, or your printer.
Problem solved.
Plz rate my solution.
thanks, and merry xmas.
Dec 21, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aqualtis LCD display language
Follow this link and read where to find your model # and insert it in the box. I hope this helps. http://genet.geappliances.com/DocSearch/Dispatcher?REQUEST=SEARCHWITHURLCONNECTION
Nov 30, 2008 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
208 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
