Question about JVC LT-32D200 LCD TV
Only showing blue red and black colors
Whats going on with my tv its showing blue red and black colors only
    Top Expert:
  • JVC Master
  • 74,482 Answers
It sounds like a display panel fault. Anyway make it sure. Check the site linked here. It has illustrations and details to faults to LCD display screens. Contact any service technician too. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Posted on Jul 11, 2013
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
Not able to get red tones on TV
the problem is at the crt base .there r three red,blue n green o/put.verify if there is dry in the soldering n check the red cathode voltage it must b around 150 .if not then check the resistor that feeds the red o/put.it could b 12 to 15k. all crt have 3 driver color red blue n green,whenever one driver not working the color changes.that wat happened to ur tv now i do not know wat model u have.the drivers may b transistors or now its ic that r being used like tda 6103q.best of luck
Jan 03, 2010 | Toshiba 27AF45 27" TV
Toshiba 50HX81 only showing black and white
I bet it's a DLP TV correct?
This symptom would indicate that the color wheel has flown apart. Which results in a monochrome only image.
Color wheels are expensive and need to be replaced by a qualified service person.
Dec 26, 2009 | Toshiba 50HX81 50" Rear Projection...
Black and white
Your not getting color probably because of a weak "air" signal. The fix is a better antenna or an antenna booster.
May 08, 2009 | Apex Digital PF2025 20" TV
Wii only shows blue, yellow and black on my HD TV
Are you trying to plug in the yellow, red ,and white cables into blue, green, and red slots? If you are you cannot because those are for HD inputs only
May 06, 2009 | Nintendo Wii Console
TV shows red
It sounds as though the color settings have been altered or that the tv is going out. Assuming this is a crt unit, you might try adjusting the color or unplugging it for a few minutes.
Good Luck,
BB
Jan 06, 2009 | Sony KV-32FS13 TV
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Nov 11, 2007 | Toshiba 50H72 50" Rear Projection...
Dvd showing in black and white
I'm assuming you're using the yellow ended video cable and two audio cables hooked up to your TV to display the signal. If so, I would just make sure they are connected in the correct output jacks on your dvd player and that they match up with the input jacks on your TV. If so, then I'd try another DVD player to see if that one plays OK.
Jan 13, 2007 | Samsung DVD-P230 DVD Player
JVC LT-32D200 LCD TV Logo
128 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
