Question about Nikon Speedlight SB-600 TTL Flash
Sb600 keeps flashing
My flash (sb600) keeps flashing every few seconds, whether it is attached or not
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Nikon Expert
  • 305 Answers
The the signal to the camera to shoot flash off the camera
change your settings
Posted on Aug 21, 2014
SOURCE: Nikon SB600 flash behaving strangely
I had the same problem. I have sent my D200 to Nikon France for repair and they solved the problem.
Posted on Apr 13, 2008
SOURCE: Nikon SB600 flash menu locked.
Nikon hot shoe is rated up to 250V (canon's is rated up to 6V) so you can use almost any tipe of flash, except maybe for old studio flashes.
Vivitar 283 (older versions) is ~200V rated, and much lower on newer versions. It should work.
Posted on May 09, 2008
MarkDay
  • 111 Answers
SOURCE: sb600 wireless mode not working...
Remember that even though sb-600 is wireless, it is based on infrared. This usually means having a clear line-of-sight between flash commander and remote flash. Any object that gets in way can block signal from flash commander. Weak batteries in flash will also cause remote operation to be sporadic.
Posted on May 15, 2008
bearydude
  • 62 Answers
SOURCE: sb600 display fine, but no longer flashes
Your flash has a bad flash tube . make sure the batteries are in corectly and youhave a ready red light .
Posted on Nov 28, 2008
  • 11 Answers
SOURCE: Underexposure with Nikon SB-600 flash
1 - Make sure you don't have your diffuser screen pulled down. This is easy to overlook and will produce that effect.
2 - Reset your flash - hold down the "Mode" and "On/off" button together for a few seconds. This gets you out of any funky mode you could have accidently put yourself in
3 - Put camera in fully auto mode. That clears any weird modes you could have gotten into there
4 - Clean the contacts on the flash and camera. I use a pencil eraser and wipe with alcohol and paper towel. Dirty contacts can cause flash misfire or cause full flash during the preflash mode, which gives you dim or dark photos or sporatic flash operation.
Posted on Mar 31, 2010
Sb900 and sb600 speedlight can work together off camera?
It sure will, the flash light will trigger the other flash go to bracketing and flash and set one flash as commander and the other slave
go to nikon tutorials setting up off camera flash have fun
Feb 05, 2014 | Nikon Cameras
I have dark pictures even with sb600 flash working. Anybody have suggestions? Is it my camera settings? I use iTTL and I think flash is not enough
I don't know what camera you have and I don't know which mode you are using (manual exposure, full auto, shutter or aperture priority, etc.) so I can only make a generalized guess. It may be related to your shutter speed. Although your camera may have a wide range, for example 10 to 1/2000 second, your flash will only be properly triggered and synced over a limited range. I would take a few pictures with the shutter at 1/60 second and see if that helps. Also, on more advanced SLR's you can select a rear curtain mode. See if that may be a factor.
Oct 23, 2011 | Nikon Speedlight SB-600 TTL Flash
Mar 07, 2010 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
Sb600 display fine, but no longer flashes
Nov 08, 2008 | Nikon Speedlight SB-600 TTL Flash
Apr 15, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 wireless mode not working...
Mar 13, 2008 | Nikon Speedlight SB-600 TTL Flash
Sb600 doesn't fire well off the sb800
The sb600 needs to be able to see the preflashes of the sb800, so this is probably caused by one of two things.  The first thing I'd check is whether or not the light sensor on the side of the sb600 was covered, blocked, or facing away from the sb800.  I've had problems outdoors when I forgot to have the light sensor face the camera.
If the sensor was facing the camera, it is possible that the flashes didn't have a good line of sight to each other.  That normally shouldn't matter, but if there is a high ceiling and lots of people, it could be the case.  I don't know if it will help, but in any case I would recommend using a StoFen Omnibounce on the sb800 to increase the likelihood that the light finds a direction where a surface to bounce off of is found.
Good luck.
Feb 02, 2008 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
120 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
