Question about Frigidaire FEQ1442ES Electric Dryer
Drying drys for one cycle, then heating element will not turn on. everything else works but element.
  • 63 Answers
Could be the high safety limiter its on the outer housing in whice the heating element is housed in the back of kenmore dryers. email back if its not a kenmore I will tell you where to look on other brands
Posted on Aug 29, 2007
SOURCE:
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
Frigidaire dishwasher model number FDB4050LHS1 making a loud squealing noise
Usually this is the drying time of the cycle. I would have a professional look into the blower assembly and heating elements of the unit.
Aug 25, 2012 | Dishwashers
Maytag mde7057ayw not drying on intelidry
Hello there and welcome to fixya
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 31, 2011 | Maytag Dryers
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
What's the difference between dry and cool setting and when should dry be used
Dry is a dehumidifier option. There is a heating element in the unit to heat the cold air back up. The cold evaporator coil causes the moisture in the air to condense on the coil (this is why the AC leaks water) and the air coming out of the vents will be cold. If you are not wanting to lower the temperature in the room but want to take out the moisture then use DRY. All ACs take the moisture out of the air when they are on COOL. So, COOL drys the air and makes it cold. DRY drys the air but warms it back up before sending it out the vents.
Jun 14, 2010 | LG LWHD2500ER Wall/Window Air Conditioner
Clothes dryer drys but no heat(electric dryer)
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 16, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer runs as usual but won't heat up.
you need to check continuity across the heating element with an ohm meter looks can be deceiving
Apr 14, 2009 | Dryers
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Kenmore Elite 67851 Dryer will not heat up
check ignitor and gas supply
Sep 10, 2017 | Dryers
Frigidaire FEQ1442ES Electric Dryer Logo
75 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
