Question about Ricoh Office Equipment & Supplies
Borderless prints How do i get borderless printing on the mp c3000
Inky
  • 691 Answers
SOURCE: R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Posted on Aug 16, 2007
  • 26 Answers
SOURCE: printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Posted on Jun 11, 2008
  • 162 Answers
SOURCE: borderless printing brother HL- 4040cn
This model can't suppor boderless printing. check this for details.
Basic Specifications Printer Type Laser/LED - Color Form Factor Desktop Color Yes Print Technology Single-pass electrophotographic laser Resolution Black Maximum Resolution, Plain 2400 x 600 dpi Speed First Page Out, seconds 16 Black Print Speed (Draft) 21 ppm Controller Specifications Processor Speed 300MHz Memory, standard 64MB Memory, maximum 576MB Languages PCL6, BR-Script3 Fonts Supported PCL: 66 scalable fonts, 12 bitmap, 13 bar codes
BR-Script3: 66 scalable fonts Special Features Borderless Printing No Automatic two-sided Printing Yes Direct CD / DVD Printing Support No Paper & Media Handling Paper trays, std. 2 Paper Input Tray1 Capacity, sheets 50 Paper Input Tray2 Capacity, sheets 250 Paper Output Bin Capacity, sheets 150 Recommended monthly volume, pages 35000 Paper Types Plain paper, bond, envelopes, labels Supported Paper Sizes Letter, Legal, Exec, A4, A5, A6, B5, B6; Envelopes: Com 10, DL Connectivity Interface(s) 10/100 Base-TX Ethernet, Hi-Speed USB 2.0, USB Direct Interface, 802.11b/g Wireless, IEEE1284 Parallel Network Ready Yes Security Features Wireless Network Security: WEP, WPA/WPA2-PSK (TKIP/AES), LEAP (CKIP), SecureEasySetup Software Details Utilities Interactive Help, Driver Deployment Wizard Windows OS Compatibility List Windows Vista/XP/XP Professional x64/2000, Windows Server 2003/2003 x64 Mac OS Compatibility List Mac OS X 10.2.4 or greater Front Panel Display Yes Physical Details Width, inches 16.5 Height, inches 12.5 Depth, inches 18.7 Weight, lbs 64.2 Additional Details Additional Details - Time to First Page: Less than 16 sec (black)/17 sec. (color)
- Optional Paper Input: Up to 800-sheet total capacity via 500-sheet paper tray
- Multi-Protocol Support: TCP/IP (ARP, RARP, BOOTP, DHCP, APIPA (Auto IP), WINS, NetBIOS name resolution, DNS Resolver, mDNS, LPR/LPD, Custom Raw Port/Port 9100, SMB Print, IPP, IPPS, FTP Server, SSL/TLS, POP before SMTP, SMTP-AUTH, TELNET, SNMPv1, HTTP/HTTPS server, TFTP client and server, SMTP Client, APOP, LLTD responder), Apple’s Simple Network Configuration for OS X 10.2.4 or greater, TCP/IP: IPv6
- Network Management Tools: BRAdmin Light, Web-based Management, BRAdmin Professional, Web-BRAdmin
- Linux OS Support: Red Hat, Mandrake, SuSE, Debian PostScript3 PPD
- Power Requirements: 120 VAC +/- 10% 50/60 Hz
- Energy Star Compliant: Yes
Posted on Nov 24, 2008
latcarf
SOURCE: MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Posted on Mar 10, 2009
SOURCE: HP C4480 Won't Print Borderless
I have hp photosmarrt c4280 printer. 4X6 photo print creating border on the right when printing directly from memory card. Creates border on the top and on the right when printing from HP Image Zone. Any suggestions?
Posted on Sep 18, 2009
I have a canon mp 240 and it Prints fine if you only need half of the document. It cuts everything in half! Like it reads the header wrong or blows up the words or make extra spaces. How can I get it to...
I thought maybe you have the paper size set to Landscape rather than Portrait. If not, then you might look at:
http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport
I did some searching on that site and it yielded the hlep below which may give you some help.
Issue: How do I set my printer so my printout fits the paper size I am using?
Solution: Use the recommended Print Area MP240
Printing Area title-bar.gif To ensure the best print quality, the machine allows a margin along each edge of media. The actual printable area will be the area inside these margins.
Recommended printing area (dark blue):
Canon recommends that you print within this area. (o_darkblue13.jpg)
Printable area (light blue):
The area where it is possible to print. (o_lightblue14.jpg)
However, printing in this area can affect the print quality or the paper feed precision.
o_area15.jpg i_note.gif Note
Borderless Printing
By selecting the Borderless Printing option, you can make prints with no margins.
bullet_s.gif When performing Borderless Printing, slight cropping may occur at the edges since the printed image is enlarged to fill the whole page.
bullet_s.gif For Borderless Printing, use the following paper.
- Glossy Photo Paper "Everyday Use" GP-501
- Photo Paper Glossy GP-502
- Photo Paper Plus Semi-Gloss SG-201
- Photo Paper Pro Platinum PT-101
- Photo Paper Plus Glossy II PP-201
-Photo Paper Pro II PR-201
- Matte Photo Paper MP-101
Performing Borderless Printing on any other type of paper may substantially reduce printing quality and/or result in printouts with altered color hues.
Borderless Printing on plain paper may result in printouts with reduced quality. Use them only for test printing. You can perform Borderless Printing on plain paper only when printing from your computer.
bullet_s.gif Depending on the type of paper, Borderless Printing may reduce the print quality at the top and bottom edges of the paper or cause these parts to become smudged.
See A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide.
See Letter, Legal.
See Envelopes.
sikaku.gif A5, A4, B5, 4" x 6", 4" x 8", 5" x 7", 8" x 10", Wide
Size
Printable Area (width x height)
A5*
5.56 x 7.95 inches / 141.2 x 202.0 mm
A4
8.00 x 11.38 inches / 203.2 x 289.0 mm
B5*
6.90 x 9.80 inches / 175.2 x 249.0 mm
4" x 6" / 10 x 15 cm
3.73 x 5.69 inches / 94.8 x 144.4 mm
4" x 8" / 10 x 20 cm*
3.73 x 7.69 inches / 94.8 x 195.2 mm
5" x 7" / 13 x 18 cm*
4.73 x 6.69 inches / 120.2 x 169.8 mm
8" x 10" / 20 x 25 cm*
7.73 x 9.69 inches / 196.4 x 246.0 mm
Wide*
3.73 x 6.80 inches / 94.8 x 172.6 mm
* This page size can be used only when printing from your computer.
o_ap_069.jpg o_darkblue6.jpgRecommended printing area
o_lightblue7.jpgPrintable area
sikaku.gif Letter, Legal
Size
Letter
8.00 x 10.69 inches / 203.2 x 271.4 mm
Legal*
8.00 x 13.69 inches / 203.2 x 347.6 mm
o_ap_074.jpg o_darkblue4.jpgRecommended printing area
o_lightblue5.jpgPrintable area
sikaku.gif Envelopes
Size
European DL*
4.06 x 7.12 inches / 103.2 x 180.8 mm
US Comm. Env. #10*
3.86 x 7.96 inches / 98.0 x 202.1 mm
* Envelopes can be used only when printing from your computer.
o_darkblue8.jpgRecommended printing area
Jun 30, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Help, my ricoh printer will only print one copy, when I need 60, yesterday :-) It's an Aficio MP C3000 Many thanks,
Hi, there is an option for how many copies to print in the printer driver. When you hit Print in the program you want to print from, a box of printer options should appear, including which printer you want to print to. There will be a field, probably about halfway down the screen, asking for the number of copies you want to print. Change this to 60 before proceeding and you will make 60 prints of your document or image. Hope that helps!
Nov 13, 2010 | Ricoh Aficio AP3800C Laser Printer
When using canon pro 9000 with photoshop on a MAC Snow Leopard computer, I cannot print borderless pictures. How can I fix this problem
Preserve your memories forever with borderless printed photographs--while saving money and time by printing from the comfort of your own home. Some printers do not have the option of printing borderless prints, so make sure your printer supports borderless printing before beginning this project.
  • Download your digital photo to your computer from a digital cameramag-glass_10x10.gif, email or the Internet. Save the photo to your hard drive to a folder that you can find later such as "Pictures."
  • Step 2Open your digital photo in a photo-viewing software. Click "Print" from your menu. Go to your printer properties to change your printer's "Page Setup." Access "Properties" through the "Preferences" or "Options" link in your "Print" dialog box. Many software programs have a default margin or border for photos; to print borderless photos, you'll have to remove the default margin.
  • Aug 04, 2010 | Canon Office Equipment & Supplies
    Epson R2400 letterhalf borderless printing
    No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
    Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
    Borderless printing with a dell 3010cn
    This is application driven and you will need to set this up from your application or when you File / Print select the Print Preferences for the Dell 3010cn and then select borderless printing
    Sep 30, 2009 | Dell Office Equipment & Supplies
    How do I print borderless pictures on my Selphy DS810?
    You print borderless by choosing that option in the print software, after choosing print, you go into printing preferences and choose borderless..
    Aug 20, 2009 | Canon SELPHY DS810 InkJet Photo Printer
    HP C6180 won't print borderless photos
    Also had ongoing problem of paper jams printing PDF files, but not when printing any other files. Solved both problems by uninstalling and reinstalling printer driver.
    Feb 03, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Jan 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Borderless printing kodak 5500, clear coating business cards
    The paper size must be set to borderless in both the application (MS Word) and the printer driver. To set borderless printing in the application, follow the steps below.
    1. Click File , then Page Setup .
    2. In the Page Setup dialog box, click the Paper tab.
    3. Under Paper Size, select the appropriate borderless paper size.
    To select borderless printing in the printer driver, follow the steps below.
    1. In the application, click File , and then click Print .
    2. In the Print dialog box, click Properties , and then click the Paper/Quality tab.
    3. Select the appropriate borderless paper size.
    HINWEIS: Under Paper Type, you cannot choose plain paper and print borderless. Choose photo or brochure paper instead. s.gif
    Nov 14, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    77 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    CheckitRight
    CheckitRight
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
