Question about AudioCodes Mediant 1000-2E1
Factory reset mediant 1000
How can I do hard reset
How to factory reset
What do you mean, "factory reset"? Do you want to reinstall the operating system, reset the CMOS, or.....? For more free in-depth help go to www.suggest-a-fix.com
which is a free computer help forum that I belong to. Post in the Hardware section and I (or someone else) will be along. This forum is not set up for complicated problems that require in-depth communication.
Jul 29, 2014 | Lenovo H520s Desktop Computer; Intel...
Samsung gt i5503 touchscreen not responsive
Step by Step Follow The Tricks
hard rest without touching the screen
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
May 18, 2012 | Cell Phones
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
Nov 20, 2011 | Dell Vostro 1000 Laptop
I am selling my computer and I would like to reset it back to factorys settings.
If you have the restore disks then you can do a factory reset. If there is no restore disk then you will have to re-install windows from the Windows Installation CD. If you do not have the CD then you may want to sell the system without any operating system.Download a boot disk called Boot and Nuke to format your hard drive before you sell the system. This will erase ALL data from your hard drive.
Jul 06, 2011 | HP Mini 1000 Netbook
How to reset e zyair g-1000
On the Zyxel ZYAIR G-1000, the reset button is the small hole between the LAN socket and the power plug socket. Simply press this button for 10 seconds, until the link LED turns red. This will reset the unit to factory default settings.
Dec 01, 2010 | Zyxel ZYAIR G-1000 (91-005-026001)...
How to reset factory default i2eye dvc-1000
Look at back or side of router you will find a small hole with a button marked reset, push this button in for a few seconds, with power OFF and this will return the router to "From the factory" settings IE: Blank
Feb 18, 2010 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Hi i need to reset my rvx 1000 to factory
Page 42 or 69:
"To reset all of the parameters to the factory-set values
Use "9 PARAM.INI" on the SET MENU to reset all of the parameter values of all DSP programs within the selected group to the factory-set values (see page 42)..."
Feb 09, 2010 | Yamaha RX-V1000 Receiver
Dell laptop inspiron 1000
Put recovery disk in the CD drive. On reboot, hold down F12 key. You should get a choice of drives to boot from. Make sure the first two are in the correct order:
1. CD-ROM (optical drive)
2. HDD (hard drive)
then press F10 to save and exit.
Now the laptop should boot correctly from the recovery disk.
Jan 06, 2009 | Dell Inspiron 1000 Notebook
Unable to get pass login window
External HDs are not usually recognised on boot, however some external CD drives are.. although most of these type of devices have a built in recovery partition, which should allow you to restore this tablet back to factory without having to resort to loading from external devices. try pressing f10 or f11 on boot or look for other messages on bootup to press a key combination if all else fails try looking for instructions on factory reset from the manufacturers website
May 08, 2007 | ViewSonic ViewPad 1000 Tablet PC
AudioCodes Mediant 1000-2E1 Logo
64 people viewed this question
Top AudioCodes Computers & Internet Experts
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
