Question about Snom 320 IP Phone
Set time On to the Snom 320 IP web interface the NTP server option is greyed out and cannot be changed from "ntp.voipfone.net" - the phones aren't receiving the correct time or date.
4 Suggested Answers
SOURCE: can't connect to phone
I bought SNOM 300 and i was unable to connect the router in first go. it was keep saying Send DHCP reqt but nothing was happening. i tried even connecting SNOM 300 dirctly to my laptop but in vain. in last i started receiving message Ethernet cable unplugged.
I reset the SNOM 300 to the factory defaults which solved the problem immediately.
Get to the phone menu "configuration-Reset" and select this option. it will ask for the admin password which is 0000. This will fix the issue. try it.
Posted on Mar 12, 2009
ted1430
  • 339 Answers
SOURCE: i forgot the password and cannot access the web interface
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Posted on Jul 12, 2009
ted1430
  • 339 Answers
SOURCE: The display on my Snom 320 doesn't work? The
Do you have the power brick hooked up to it? If so, try another one if possible as it could be the defective component.
If you're using POE to power it, make sure you have pluggd into a POE port for sure.
If you still have problems after this, then you need to return it for replacement unit.
Posted on Oct 01, 2009
How to change date and time to MAG 254 Box.
Enter the "System settings" - by pressing «Setup», «Services» or «SET» on the remote control (depending on the version the remote control)
- Select "Servers"
- In the input field "NTP server" enter "pool.ntp.org"
- Confirm "OK"
- Reboot mag250
Oct 15, 2016 | Computers & Internet
Tip
DHCP Server configuration in Linux
Linux is a UNIX based operating system. It is a server operating system. REDHAT Linux is Enterprise version of Linux. Now a day's Most of corporate sectors use red hat Linux as server in their company because it is secure very much.
Full form of DHCP "Dynamic Host Configuration Protocol. DHCP server assigns IP addresses and other network configuration information like subnet mask, broadcast address, etc to computers on a network. The DHCP assignments are the following.
Lease Request: Client broadcasts their request to DHCP server with a source address of 0.0.0.0 and a destination address of 255.255.255.255.
IP lease offer: DHCP server replies with an IP address, subnet mask, network gateway, name of the domain, name servers, duration of the lease and the IP address of the DHCP server.
Lease Selection: Client receives offer and broadcasts to al DHCP servers that will accept given offer so that other DHCP server need not make an offer.
The DHCP server then sends an ack to the client. The client is configured to use TCP/IP. Lease Renewal: When half of the lease time has expired, the client will issue a new request to the DHCP server.
Installation of DHCP server: First of all while install the RedHat Linux enterprise version server be careful about the ports and the services must be turned on. To create DHCP server in Linux first download DHCP RPM package and install with "rpm-ivh" command. Where I have done it there I have create YUM server, so easily I have download and install it by YUM (yum install dhcp version). DHCP package will locate in /usr/share/doc/at Linux file system. I copied the DHCP's files from /usr/share/doc/ to /etc/dhcpd.conf.. Then I started to configure the dhcpd.conf file to route the DHCP server in there local network. I have open the configuration file with "vi" command. Then commented out the lines from "default gateway to option netbios" because system don't read the commented lines. After that I set the range of IP address in dynamic- bootp of their local assumption of system. I have change the "next-server" with the dhcp server name and have also change the fixed address with the dhcp server IP address (end range of dynamic IP). It is very easy job to configure DHCP server. After configure the .conf file of dhcp just turn on the service with "chkconfig" command and restart the dhcp service. After that entire job I reboot the system. And after rebooting of server I turned on the other client system. While startup the client system without static IP address all of those picked up IP from dhcp server and going on successfully. I have prefer the command line mode to do the total job.
The DHCP server configure file is following:
ddns-update-style interim
ignore client-updates
subnet 192.168.1.0 netmask 255.255.255.0 {
# The range of IP addresses the server
# will issue to DHCP enabled PC clients
# booting up on the network
range 192.168.1.201 192.168.1.220;
# Set the amount of time in seconds that
# a client may keep the IP address
default-lease-time 86400;
max-lease-time 86400;
# Set the default gateway to be used by
# the PC clients
option routers 192.168.1.1;
# Don't forward DHCP requests from this
# NIC interface to any other NIC
# interfaces
option ip-forwarding off;
# Set the broadcast address and subnet mask
# to be used by the DHCP clients
option broadcast-address 192.168.1.255;
option subnet-mask 255.255.255.0;
# Set the NTP server to be used by the
# DHCP clients
option ntp-servers 192.168.1.100;
# Set the DNS server to be used by the
# DHCP clients
option domain-name-servers 192.168.1.100;
# If you specify a WINS server for your Windows clients,
# you need to include the following option in the dhcpd.conf file:
option netbios-name-servers 192.168.1.100;
# You can also assign specific IP addresses based on the clients'
# ethernet MAC address as follows (Host's name is "laser-printer":
host laser-printer {
hardware ethernet 08:00:2b:4c:59:23;
fixed-address 192.168.1.222;
# List an unused interface here
subnet 192.168.2.0 netmask 255.255.255.0 {
on Mar 17, 2011 | Computers & Internet
Issue with time synchronizing(NTP) on layer 2 switch
I know this is probably not going to help you out but you did try going to Alcatel-Lucents web page and search through there or calling them at 800 995-2696? Good Luck! Sorry I couldn't be of some help
Mar 04, 2014 | Alcatel OmniSwitch 6850 (OS6850-48)
HOW DO I CHANGE THE TIME OR FIND OUT WHAT TIME THE PHONE IS ON?
Hi time is set on the PBX depending on the version of CM its either done on the web interface or from the command line. If you are on > CM1 there is an NTP section to add a network time protocol server IP address, the pbx will correct the timeslip with that server
see support.avaya.com for more details
Oct 21, 2009 | Avaya Definity 8410D Phone
How to change the IP address manually - through phone interface?
Go here for directions on disabling DHCP:
http://wiki.snom.com/Settings/dhcp
Once DHCP is turned off, you should have the option to manually configure the IP address.
May 25, 2009 | Hawking HWREG1 Repeater
How do I change the time on clock
Login to the web page for the system and choose Maintenance. There is an option to set the date and time.
It is also possible to set the system up to get the time from an NTP source.
If you have a dual server solution e.g. S87xx it is recommended the standby server is done first.
Mar 05, 2009 | Avaya Lands Phones
Can´t CONNET to AD
You have to make sure that the clock of your NAS is synchronized with the ActiveDirectory. Configure your NAS to use NTP. This should be under the clock configuration screen. Enter the IP address of your domain controller(s) as the NTP server address.
Also, it would be a good idea to make sure that you domain controllers are synchronized with a root time source (on the Internet). In order to do that, run the following command on all you DCs.
C:\>net time /setsntp:br.pool.ntp.org
Of course, your DCs must be able to access the internet on port UDP 123.
Judging by your email address, you seems to be located in Brasil. If you are not in Brasil, you may look for another NTP server http://support.ntp.org/bin/view/Servers/NTPPoolServers
Feb 02, 2008 | Intel SS4000-E (SS4000ENA)
NTP
Step 1: Log into the router´s web utility and click on Tools and select Time. Step 2: You will need to set the time zone corresponding to your location. Step 3: If you set the time manually, select the date/time and set Daylight Saving (if applicable), click Set Time, click Apply, and click Continue. Step 4: If you have the IP of an NTP server, enter that IP address in the default NTP server box, click Apply and click Continue. If you leave the box empty, the router will use its default NTP servers.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
How does the router synchronize time?
The router pulls it's time like any computer. It uses the Network Time Protocol or (NTP). In order to utilize the NTP a valid Internet connection must be achieved. Network Time Protocol (NTP) is a protocol that is used to synchronize computer clock times in a network of computers. NTP is now an Internet standard. In common with similar protocols, NTP uses Coordinated Universal Time (UTC) to synchronize computer clock times to a millisecond, and sometimes to a fraction of a millisecond. UTC time is obtained using several different methods, including radio and satellite systems. Specialized receivers are available for high-level services such as the Global Positioning System (GPS) and the governments of some nations. However, it is not practical or cost-effective to equip every computer with one of these receivers. Instead, computers designated as primary time servers are outfitted with the receivers and they use protocols such as NTP to synchronize the clock times of networked computers. Degrees of separation from the UTC source are defined as strata. A radio clock (which receives true time from a dedicated transmitter or satellite navigation system) is stratum-0; a computer that is directly linked to the radio clock is stratum-1; a computer that receives its time from a stratum-1 computer is stratum-2, and so on. The term NTP applies to both the protocol and the client/server programs that run on computers. The programs are compiled by the user as an NTP client, NTP server, or both. In basic terms, the NTP client initiates a time request exchange with the time server. As a result of this exchange, the client is able to calculate the link delay, its local offset, and adjust its local clock to match the clock at the server's computer. As a rule, six exchanges over a period of about five to 10 minutes are required to initially set the clock. Once synchronized, the client updates the clock about once every 10 minutes, usually requiring only a single message exchange. redundant servers and varied network paths are used to ensure reliability and accuracy. In addition to client/server synchronization, NTP also supports broadcast synchronization of peer computer clocks. NTP is designed to be highly fault-tolerant and scalable.
Feb 16, 2006 | Belkin DSL Gateway Router (f5d5230-4-dl)
Feb 16, 2006 | Belkin (F5D5230-4) Router
Open Questions:
Cannot dial out on an SNOM320 SIP Phone I have forwarded the ip address of the phone through the router as a DMZ. I can call out using the software on my computer without any issues but not using the phone. Here is the log file information: System Information: Phone Type: snom320-SIP MAC-Address: 0004132C7E7D IP-Address: 192.168.1.101 Firmware-Version: snom320-SIP 8.7.3.19 Firmware-URL: http://provisioning.snom.com:80/download/fw/snom320-8.7.3.19-SIP-f.bin Production Information: Mac:0004132C7E7D;Version:Standard;Hardware:snom320 (H: R2A);Date:25/06/08;Copyright(C) snom technology AG Uptime: 0 days, 0 hours, 1 minutes LCS: 0 days, 0 hours, 0 minutes (0) Memfree: 1580 K CPU: 0.03 0.01 0.00 1/10 10 Bootloader-Version: 1.1.3-u Expansion Module: (0) SIP Identity Status: Identity 1 Status: 12262898960@voip.freephoneline.ca: OK Identity 2 Status: Identity 3 Status: Identity 4 Status: Identity 5 Status: Identity 6 Status: Identity 7 Status: Identity 8 Status: Identity 9 Status: Identity 10 Status: Identity 11 Status: Identity 12 Status: Ethernet Status: Net Port: Connection Type: 100 Mbit Full Duplex Status: connected PC Port: Connection Type: Status: not connected Call being received by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 Call being placed by Snom320: 9/2/2013 11:28:08 [NOTICE] PHN: RTP: set_destination adr=208.85.216.38:11468 9/2/2013 11:28:36 [NOTICE] PHN: TPL: Socket 31 idle/connect timeout 9/2/2013 11:29:01 [NOTICE] PHN: SDP: Skipped Codec G723 is not supported for 20 ms packets 9/2/2013 11:29:02 [WARN ] PHN: SIP: process_registrar_packet: 401 needs 128 bit nonce 9/2/2013 11:29:02 [NOTICE] PHN: SIP: process auth:Match challenge for user=12262898960, realm=voip.freephoneline.ca 9/2/2013 11:29:22 [NOTICE] PHN: TPL: Socket 32 idle/connect timeout 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transaction_timeout udp: 1000018 (32000) 9/2/2013 11:29:34 [ERROR ] PHN: SIP: transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:34 [NOTICE] PHN: SIP: Add dirty host: udp:208.65.240.170:5060 (0 sec) 9/2/2013 11:29:34 [NOTICE] PHN: SIP: final transport error: 1000018 -> udp:208.65.240.170:5060 9/2/2013 11:29:35 [ERROR ] PHN: SIP: transport error 1000018: generating fake 599 9/2/2013 11:29:37 [NOTICE] PHN: Fetching URL: snom://mb_exit 9/2/2013 11:30:35 [NOTICE] LID: testNetworkPolicyIsSet This has been frustrating me for a long time and I would appreciate any suggestions. Thanks.
Feb 09, 2013 | Snom 320 IP Phone
Snom 320 IP Phone Logo
122 people viewed this question
Top Snom Computers & Internet Experts
David Payne
David Payne
Are you a Snom Computer and Internet Expert? Answer questions, earn points and help others
