Question about Kyocera Office Equipment & Supplies
My printer states " load cassette letter". I have done everything I can do. Please help.
My Kyocera FS-1370DN has an error message that states, "load cassette letter". I have don all that I know to do. Pleas help.
5 Suggested Answers
  • 25 Answers
SOURCE: Kyocera FS 4000 cassette error
under the front of the cassette on the bottom is a white catch if you pull it towards you the paper will spring up. more then likely it is not automatically getting pushed when you put the cassette in.
if this is not correct if you take the cassette out and look in where you took it out of there should be a arm hanging down just left of center that is the paper out sensor arm of that is broken it could be your problem also
Posted on Jan 07, 2009
acdr
  • 1913 Answers
SOURCE: I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Posted on Mar 21, 2009
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
caroldon
  • 17130 Answers
SOURCE: KYOCERA ECOSYS FS-C5100 DN PRINTER. WHEN I TURN IT
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Posted on Sep 26, 2011
Where is developer unit in kyocera fs 1370dn
the developer unit for this printer looks like this.
26367533-y50xtmg3b3sor10el1acrrt1-1-0.jpg The unit can be found under the toner cartridge.
Here is a link on how to remove the toner cartridge.
okm2000 de Kyocera FS 1370DN 1370 1350 1320 Tonerwechsel Kopierer Drucker...
Best regards,
Marius
Nov 22, 2016 | Kyocera FS-1370DN
What does Call service 4000:0047918 mean?
it means that the durm is not sitting correctly!
Feb 18, 2016 | Kyocera FS-1370DN
Where do I load paper in a Kyocera FS-C5350DN Full-Color Laser Printer
At the bottom of the printer you will find the paper cassette. Pull the handle and the cassette will slide out. Eventualy you will need to ajust the size of the paper.
Jun 23, 2014 | Kyocera FS-2000D Laser Printer
KYOCERA FS 1370DN 7990 0088329
Empty the waste toner from the back side of the drum unit. Then remove and reinsert the waste toner sensor connector from the controller assy (main pwb).
Jun 02, 2014 | Kyocera FS1370DN Laser Printer
ERROR CODE 7990:0094346
7990 indicates that your waste toner is full..
Emptying the waste toner will get rid of the code!
Feb 25, 2014 | Kyocera fs 1370dn laser printer
My kyocera fs-1370dn suddenly says it is missing a developer unit when the developer unit is there and was just working
Check that the toner you are using is genuine Kyocera, also that the toner hasn't run out, this is normally a toner related issue.
Dec 21, 2012 | Kyocera FS-1370DN
" Load MP Tray Letter"
Pull down the MP tray and load paper into it.
Jan 05, 2009 | Office Equipment & Supplies
Dec 16, 2008 | Kyocera FS-4000DN Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Kyocera load a casset
check the paper size dial on the left inside of cassette draw.
May 04, 2008 | Kyocera Mita FS-1920 Laser Printer
376 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
