Question about Dishwashers
How to install Protector PART NUMBER: 3369761
Roper dishwasher, it came off
Roper dish washer not cleaning the dish, it is a rud4000mq Id # fs2941518
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 19, 2011 | Roper 24 in. RUD4000M Built-in Dishwasher
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Cant get the protector inlet (part#8268390) off
The manufacturer has replaced part number 8268390 with part number 8531857. Manufacturer part number 8531857 is RepairClinic.com item number 1060487.
Oct 09, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Water in back of Roper dishwasher
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
May 19, 2010 | Roper 24 in. RUD1000DB Built-in Dishwasher
I need to clear debris from under the inlet protector. The two screws and the foreign object protector have been removed, but the inlet protector seems stuck in place. Is there a trick to pulling it out?...
Hi Steve,
I am not sure on what you are calling the inlet protector. Check out this link and let me know if it is one of the pieces that are called out here and the number it corresponds to.
This link shows how to clean out the sump so not every part in there is shown.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Roper dishwasher washes, seems to run normally, but leaves a couple inches of water in the bottom when done
If the drain is stoped this will happen. Is it a new instalation? If into a disposer did you knock out the plug in the disposer. Check the drain line
Oct 17, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Dont know how to start it
Roper is a subsidiary of whirlpool. Call this number and they should be able to help with all operating questions.
1-800-447-6737
Hope this helps,
Kermit
Aug 24, 2008 | Roper 24 in. RUD1000DB Built-in Dishwasher
Roper dishwasher
Here is the link to the user manual if you need it; http://www.roperappliances.com/data/8575997.pdf Page 17 gives all the numbers to call for replacement front panels. here is the link to the installation manual; http://www.roperappliances.com/data/3385181.pdf Page 13 onwards tells you all you need to change the panel. Hope this helps :)
Mar 16, 2007 | Roper 24 in. RUD1000DB Built-in Dishwasher
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
